Page 1 of 2
Domoticz esp8266 ds18b20
Posted: Wednesday 03 August 2016 23:17
by pmalvino
hello
I am building a home automation system with a raspberry running Domoticz and several esp8266 to control windows blinds, ligths and solar water panel.
you can see my tipical board in
https://easyeda.com/pmalvino/blinds_con ... -QaUNHBvN5.
tbe control is working ok but i am trying to configure Espeasy and Domoticz to read a DB18B20 sensor and i cant do it.
in the espeasy i can see the temperature value, but in the domoticz page the value dont update.
can you help me?
Re: Domoticz esp8266 ds18b20
Posted: Friday 05 August 2016 17:57
by pmalvino
- domoticz devices.jpg (228.88 KiB) Viewed 8416 times
Re: Domoticz esp8266 db18b20
Posted: Friday 05 August 2016 18:39
by Herman-H
Did you fill the correct value for IDX / Var: in ESPEasy?
BTW, means escritorial = virtual?
This what i have:
- Dallas.JPG (14.98 KiB) Viewed 8411 times
Posted: Friday 05 August 2016 19:02
by bizziebis
Did you also set a 'Delay' of 60 or so for the temperature sensor in ESPEasy?
Posted: Saturday 06 August 2016 19:24
by pmalvino
thank you for your reply.
in the espeasy in idx i put 20.
in the sensor delay i have 60.
Posted: Saturday 06 August 2016 19:27
by pmalvino
and escritorio is the part of the house where i have the esp8266.
its the name that i put in espeasy main settings name.
Posted: Tuesday 09 August 2016 14:59
by pmalvino
hello, problem solved.
I made a new installation of domoticz raspberry pi image and now i have temperature from the sensor.
thank you all for the help.
Posted: Tuesday 09 August 2016 21:14
by Derik
mmm
do you now there is the espeasy project:
http://www.esp8266.nu/index.php/Main_Page
with level control and device check etc..
Fully integrated with domoticz..
Posted: Sunday 18 September 2016 19:40
by reddo
Got it working... flashed the ESP with Espeasy version 120, 512 kb (strange, black seems to be 1024 but that does not work on mine) and a DS18B20 on the GPIO2.
I see the esp wireless, log in, chance the settings to my netowork and reoboot. Shows up in my network then after which I log in, configure the IP adress and credentials for domoticz, assign the DS18B20 and submit. Then the right temp shows up in the esp log and also in domoticz I see the correct temp in the system. But only a few minutes, then the ESP disappears from the router (gets an IP assigned based on the MAC) and from there, reflash and all and with some luck back working... but all seems very unstable...
Any ideas ?
Posted: Sunday 18 September 2016 20:48
by Derik
First try without a device..
To let the esp run..
Create a dummy in domoticz for the uptime and the ram..
Check how long the stable time is...
Then a sensor..[ ds18b20] can be instable to.
Use a motion or ...
And use a other pin...
GPIO 2 = D4 = antenna pin..
check pinout esp...
Posted: Sunday 18 September 2016 22:06
by reddo
Tried most... resets, pins high..low.. firware flash seems to work but that's about it at the moment....
Posted: Sunday 18 September 2016 22:16
by Derik
reddo wrote:Tried most... resets, pins high..low.. firware flash seems to work but that's about it at the moment....
Printscreens...
Your pin is the problem... [ i use 4 esp without problems... ]
- ScreenShot019.jpg (58.08 KiB) Viewed 7975 times
- ScreenShot018.jpg (66.8 KiB) Viewed 7975 times
Posted: Monday 19 September 2016 18:07
by reddo
Ok, up an drunning now without anything attached... still... flashing 512 works, 1024 doesn't. But as long as it keeps running I'm happy.
Edit... 5 mins later... gone......
Posted: Monday 19 September 2016 18:09
by Derik
reddo wrote:Ok, up an drunning now without anything attached... still... flashing 512 works, 1024 doesn't. But as long as it keeps running I'm happy.
Make a dummy counter..
An set this in the ESP so you can monitor the esp...
Running for x time then place a sensor [ Ds incl resistor ] ...
Posted: Monday 19 September 2016 20:36
by reddo
now flashed through Arduino IDE.. so far so good..... dummy counter made and the esp pointed to that ID... lets see
Edit : New record... 23 minutes online..... and still running. And keeping in contact with Domoticz too apparently
Posted: Monday 19 September 2016 21:04
by Derik
reddo wrote:now flashed through Arduino IDE.. so far so good..... dummy counter made and the esp pointed to that ID... lets see
There is no problem when the esp offline for 1 or 2 seconds...
After that the esp works like charme..
Sometime my esp runs 30 days. ad sometime 1 day..
No problem by me..
Posted: Monday 19 September 2016 21:21
by reddo
Was cheering too soon.. pretty soon after... lost it and it did not come back. Trying again.
Posted: Monday 19 September 2016 21:39
by Derik
reddo wrote:Was cheering too soon.. pretty soon after... lost it and it did not come back. Trying again.
Make some screendumps please to let us see what your are doing and have @ this moment..
Posted: Monday 19 September 2016 22:17
by reddo
This worked once... after that, no more...
http://www.esp8266.nu/index.php/Tutoria ... y_Firmware
and now back to the normal flashing but again, after restart (and remove the gnd from gpio0 at power down) no return of network....
I have it connected to a FDTI232 like this
and power down after flash, remover the wire to GPIO0 and then repower. Then, sometimes it shows up with the ESP_0 network but mostly it does not... very irattic.....
starting to think... maybe power it from a seperate source... ? No idea how much a FDTI232 can supply but it flashes my arduinos no problem....
Posted: Monday 19 September 2016 22:51
by mvzut
reddo wrote:starting to think... maybe power it from a seperate source... ? No idea how much a FDTI232 can supply but it flashes my arduinos no problem....
Don't know exactly where I read it, but I believe it's generally advised not to use these small usb-to-serial adapters for permanently powering ESPs. I have mine running on separate PSUs (a 3/5 V voltage regulator and a basic 5V PSU from AliExpress).
