Domoticz and RS-485 connection
Posted: Wednesday 03 August 2016 19:42
by maciekelga
I have a question to control device with Domoticz trought serial interface RS-485.
Currently I have Exta Free system in my home, is very simple system for control lightnings.
http://extafree.pl/en/
I have few modules for control lightning on/off without feedback, just send a command. Is possible to control modules trought RS-485 translator RS485/EXTA FREE RXM-0.
Is it possible to control with Domoticz by sending information.
I` dlike to control lights by Domoticz use my Exta Free system. When I press switch light in Domoticz, it have to be send to RS-485 translator.
Any advice?
Re: Domoticz and RS-485 connection
Posted: Sunday 07 August 2016 23:40
by maciekelga
Any news?
LG G2 mini
Posted: Monday 08 August 2016 8:13
by pj-r
You have to have separate app or script what does the actual modbus call. You can call this app/script from "on action" and "off action" field in switch settings(edit switch).
Posted: Monday 08 August 2016 12:24
by Toulon7559
Perhaps this thread gives some ideas how to implement an RS485-interface for your application:
http://www.domoticz.com/forum/viewtopic.php?f=14&t=5808
Posted: Sunday 21 August 2016 16:35
by maciekelga
pj-r Do You have any example?
I was also thinking to use Arduino and mysensor gateway connected via usb to domoticz.
Posted: Sunday 21 August 2016 16:36
by maciekelga
I`d like to write a program in Python which send a string use a MODBUS RTU as master. I will use in Domoticz script lua assigned with switch which will start python program.
For example: I press light switch, then lua script will start program in python which will start send command trough Modbus?
Is it correct way?
Anybody can write me program like that? I will Pay ofcourse..
Posted: Monday 22 August 2016 10:51
by pj-r
Take a look at https://minimalmodbus.readthedocs.io/en ... ical-usage. Just remove the read part and set correct values and you are good to try.
After first tests you can add command line arguments reading. So you can give command line parameters of where to connect and what switch and what value. http://www.tutorialspoint.com/python/py ... uments.htm
I think there is plenty of examples on internet.
Posted: Thursday 20 September 2018 14:07
by kksakonstruktor
Hi did you connect your exta free by rs485 ?
Jeśli udało się to proszę o info jak rozwiązałeś modbus.
