Entry detection
Posted: Monday 01 August 2016 21:25
Im looking for a way to see when someone enters/exits a door way (door is unlikely to be opened/closed)
I did a little poking around and found a 'dual beam' sensor, which is kind of what i want, but they are mostly bulky.
Ideally what would be nice is something i could put in to the trim of the door and potentially hook up to the power where the light switch is (might be mess so not opposed to a battery solution) but basically I want it to act like a garage door trip sensor.
The idea is that i'd like to turn the light on/off when you enter/leave the room and I want it to be responsive to the action of entering/exiting the door and not so much movement based.
I feel like there should be some sort of device thats like 1/2 inch in diamter that i could just drill a hole on both sides of the door jam and hell, even on the door itself which could in a perfect situation detect when the door is shut but also when someone enters/exits
the trim is nicely painted so I'd hate to have to pop it off, but that could be done if really needed
something like this in size/style
http://aeotec.com/hidden-z-wave-door-sensor
only ir/laser based. I cant find out for sure, but i think this is pressure based.
