I have a zipato keypad will try it out. hope I remember how the thing works again
I totally forgot I had one
My zipato keypad is recognized as a Schlage Link Mini Keypad RFID in the hardware openzwave window.
I added one RFID tag using start user code enrolment.
- Screen Shot 2016-08-03 at 14.43.49.png (243.13 KiB) Viewed 2944 times
I got these devices, the only one I am able to switch is the "RFID Alarm Level" which is Off at home, On when away.
RFID Switch does nothing... do not know what it does.
- Screen Shot 2016-08-03 at 14.37.08.png (98.48 KiB) Viewed 2944 times
I seen in the log that when I open the device these changes:
2016-08-03 14:57:20.597 OpenZWave: Alarm Level: Tamper
2016-08-03 14:55:10.173 (ZWave) Light/Switch (RFID Alarm Type)
2016-08-03 14:55:10.625 (ZWave) Light/Switch (RFID Alarm Level)
2016-08-03 14:55:10.630 (ZWave) Light/Switch (RFID Burglar)
But RFID Burglar NEVER goes back to off after you closed the case NEVER (you have to do that manually).
Ow, it just send "On" on every opening of the case... (an off would be nice
Same goes for: RFID Alarm Type will only send Off and RFID Access Control will only send On
2016-08-03 14:59:04.987 OpenZWave: Alarm Level: Secure
2016-08-03 14:59:04.987 (ZWave) Light/Switch (RFID Alarm Type)
2016-08-03 14:59:04.992 (ZWave) Light/Switch (RFID Alarm Level)
2016-08-03 14:59:04.997 (ZWave) Light/Switch (RFID Access Control)
Then setting away...
i do not get why I get tamper it should be away
2016-08-03 14:59:54.733 OpenZWave: Alarm Level: Tamper
2016-08-03 14:59:54.733 (ZWave) Light/Switch (RFID Alarm Type)
2016-08-03 14:59:54.739 (ZWave) Light/Switch (RFID Alarm Level)
2016-08-03 14:59:54.744 (ZWave) Light/Switch (RFID Access Control)
The only thing that changes from on to off is RFID Alarm Level.
Anyway... after the break will look into security panel of domoticz... (i really forgot I had this thing)
Btw i'm working off,...
https://www.domoticz.com/wiki/Zwave#Usi ... Tag_Reader
https://www.domoticz.com/wiki/Alarm_Setup
https://www.zipato.com/wp-content/uploa ... l-v1.4.pdf
ANywy...
Stange behaviour when entering a wrong code (for either away/home)
2016-08-03 15:26:46.741 Error: OpenZWave: Received new User Code/Tag, but we are not in Enrollment mode!
So the switch to use is: RFID Alarm Level.
-- Title: script_device_AlarmPanel.lua
-- Date: 3-8-2016 (updated)
-- this script switches the Alarm Status according to the (Zipato/Schlage Link Mini) RFID Keypad.
if (devicechanged['RFID Alarm Level']) then
if (otherdevices['RFID Alarm Level'] == 'On') then
print('AlarmPanel Arm Away')
commandArray['Domoticz Security Panel'] = 'Arm Away'
print('AlarmPanel Disarm')
commandArray['Domoticz Security Panel'] = 'Disarm'
commandArray['Keypad Ack'] = 'On'
btw no idea what commandArray['Keypad Ack'] = 'On' does. It was in the original script, I just left it in.
So this seems to work... but the big question is if this really happened... commandArray['Security Panel'] = 'Arm Away'
(another thee break)
Ok, for some reason none of the event did anything... (after it worked for 2 seconds) anyway I did not have the security panel
in my switches but when I restarted domoticz it was there and it worked... (no idea how, I only fooled around with the security panel hoping I could set it up there)
- Screen Shot 2016-08-03 at 16.13.54.png (20.79 KiB) Viewed 2934 times
