temp comparison
Nomader
temp comparison
Post by Nomader »
Can anyone help me why the following is not working...The email part is working ok.. but the temperature is not..I am using a virtual sensor which is getting the temp from WU.. i am also using the script to split the values in WU data. wu_temp is my virtual temperature sensor which works fine.
I have also tried blocky but no luck aswell
if (tonumber(devicechanged['wu_temp']) > 10.5 ) then
    commandArray[1]={['SendEmail']='Subject# #[email protected]'}
this is my log:
 2016-08-01 01:38:49.304 EventSystem: Script event triggered: C:\Program Files (x86)\Domoticz\scripts\lua\script_device_sensorWU.lua
2016-08-01 01:38:49.307 Error: EventSystem: in script3: [string "commandArray = {}..."]:3: attempt to compare number with nil
2016-08-01 01:38:49.082 (Weather Underground) Temp + Humidity + Baro (TEMP_HUM_BARO)
2016-08-01 01:38:49.475 Error: EventSystem: in script3: [string "commandArray = {}..."]:3: attempt to compare number with nil
2016-08-01 01:38:49.392 (Weather Underground) Wind (WIND)
2016-08-01 01:38:49.653 Error: EventSystem: in script3: [string "commandArray = {}..."]:3: attempt to compare number with nil
2016-08-01 01:38:49.558 (Weather Underground) UV (UV)
2016-08-01 01:38:49.819 Error: EventSystem: in script3: [string "commandArray = {}..."]:3: attempt to compare number with nil
2016-08-01 01:38:49.736 (Weather Underground) Rain (RAIN)
2016-08-01 01:38:49.902 (Weather Underground) General/Visibility (Unknown)
trixwood
Re: temp comparison
Post by trixwood »
Your script runs on any device change. And it's possible your device has not changed. And thus is not in that array (hence the nil).
You probabaly want something like:
if (devicechanged['wu_temp']) then
   if (otherdevices_svalues['wu_temp'] > 10.5 ) then
Nomader
Re: temp comparison
Post by Nomader »
i tested that, (although i don't understand what (otherdevices_svalues['wu_temp'] does.. but still the event is not starting...
trixwood
Re: temp comparison
Post by trixwood »
Sorry i think i forgot the tonumber :-( It's late, tired)
   if (tonumber(otherdevices_svalues['wu_temp']) > 10.5 ) then
Maybe it is... without s_values i always get confused between those two.
   if (tonumber(otherdevices['wu_temp']) > 10.5 ) then
Need to catch zome Zzzs... good luck!
Nomader
Re: temp comparison
Post by Nomader »
thanks for answering... but i tried both, the event is not triggered... this is very frustrating :)
trixwood
Re: temp comparison
Post by trixwood »
Then it's time to use the print statements to debug:
print ('Device wu_temp changed:' .. devicechanged['wu_temp'])
   print ('Device value:' .. tonumber(otherdevices['wu_temp']))
And a fresh restart of domoticz would be nice. Sometimes the event system does not reset itself properly.
Sleeeepp....
Nomader
Re: temp comparison
Post by Nomader »
good morning :)
nothing again
 2016-08-01 10:43:52.259 EventSystem: reset all device statuses...
2016-08-01 10:43:52.260 EventSystem: Started
2016-08-01 10:44:02.859 LUA: WU Script Parsed Temp=32.2 Humidity=27 Pressure=1011
2016-08-01 10:44:02.955 EventSystem: Script event triggered: C:\Program Files (x86)\Domoticz\scripts\lua\script_device_sensorWU.lua
2016-08-01 10:44:02.958 Error: EventSystem: in script5: [string "commandArray = {}..."]:2: attempt to concatenate field 'wu_temp' (a nil value)
2016-08-01 10:44:02.726 (Weather Underground) Temp + Humidity + Baro (TEMP_HUM_BARO)
2016-08-01 10:44:03.200 Error: EventSystem: in script5: [string "commandArray = {}..."]:2: attempt to concatenate field 'wu_temp' (a nil value)
2016-08-01 10:44:03.044 (Weather Underground) Wind (WIND)
2016-08-01 10:44:03.370 Error: EventSystem: in script5: [string "commandArray = {}..."]:2: attempt to concatenate field 'wu_temp' (a nil value)
2016-08-01 10:44:03.277 (Weather Underground) Rain (RAIN)
2016-08-01 10:45:14.068 EventSystem: reset all events...
temp domoticz.JPG (150.85 KiB) Viewed 6995 times
trixwood
Re: temp comparison
Post by trixwood »
i'm incapacitated when no sleep, made the same mistake as you.
--the following can not work.... can't print a nil value... sleepy me...
--print ('Device wu_temp changed:' .. devicechanged['wu_temp'])
   print ('Yeah, device changed')
Nomader
Re: temp comparison
Post by Nomader »
i thought you slept enough yesterday :P
1still i get nothing.. the log has no trace of the script trigering at all.. i restart domoticz every time..
Nomader
Re: temp comparison
Post by Nomader »
update:
i changed wu_temp with the mother device of WU
if (devicechanged['TEMP_HUM_BARO']) then
if (tonumber(otherdevices['wu_temp']) > 10 ) then
that did send an email succesfully.. but it did not print any other thing... so your code seems corect.. but domoticz can not handle the virtual sensor somehow
2016-08-01 11:28:54.749 EventSystem: Started
2016-08-01 11:29:05.425 LUA: WU Script Parsed Temp=32.8 Humidity=25 Pressure=1011
2016-08-01 11:29:05.588 EventSystem: Script event triggered: C:\Program Files (x86)\Domoticz\scripts\lua\script_device_sensorWU.lua
2016-08-01 11:29:05.592 LUA: Device value:32.8
2016-08-01 11:29:05.592 EventSystem: Script event triggered: script5
2016-08-01 11:29:05.284 (Weather Underground) Temp + Humidity + Baro (TEMP_HUM_BARO)
2016-08-01 11:29:05.687 (Weather Underground) Wind (WIND)
2016-08-01 11:29:05.954 (Weather Underground) Rain (RAIN)
2016-08-01 11:29:10.105 Notification sent (Email
can you explain to me what does "otherdevices" mean in if (tonumber(otherdevices['wu_temp']) > 10 )
trixwood
Re: temp comparison
Post by trixwood »
I'm still sleepy :-) Good it works.
is
strange it does not get triggered...
still sleepy..... Zzzz....
Nomader
Re: temp comparison
Post by Nomader »
so it prints ok and it does the comparison of the temperature ok... the only thing is I can not trigger it correctly
print ('Device value:' .. tonumber(otherdevices['wu_temp']) what does the "otherdevices" mean?
trixwood
Re: temp comparison
Post by trixwood »
devicechanged is an array of devices which have changed value since the last loop.
otherdevices is an array with all main values of all the devices.
otherdevices _svaluesis an array with all the values of all the devices with all there values (if then have more then one).
means if the value of the device 'wu_temp' (convert to number first) is bigger then 10 then ...
not sure why the virtual switch is not working...
Nap time.
Nomader
Re: temp comparison
Post by Nomader »
thank you very much, you 've been more than helpfull
