Wemo Motion
Posted: Friday 29 July 2016 16:11
by D5120
Hi, new to the forum, and fairly new to Domoticz.
I have the majority of my home automation set up and working, including Harmony Remotes, Phillips Hue lights, Netatmo weather sensors, and a number of dummy devices doing a lot of cool stuff.
I'm really struggling with the final piece of the jigsaw, and wondered if somebody could offer some assistance.
Using the Wemo shell script from the Wiki, I'm able to control all my Wemo sockets, which is cool.
Additionally on my network, I have Wemo Motion detector. The suggestion the Wiki is to use ouimeaux. Due to the amount of devices on my network, ouimeaux runs dog slow, and times out before seeing all my Wemo devices, so I've gone back to the shell script.
So, this is my logic
I've created a number of shell scripts (I know I could have done most of it in one script, however I was testing each bit as I went)
wemo_motion_main.sh
Calls a shell scripts that gets the state, and calls another script if motion detected, if not, exit
#!/bin/bash
status(){
doit=$(/home/pi/domoticz/scripts/wemo/wemo_motion_state.sh)
status
echo $doit
if [ "$doit"  = "ON" ]
then
echo "Motion Detected"
/home/pi/domoticz/scripts/wemo/wemo_motion_update.sh
echo "No Motion Detected"
fi
Simply get the state of the motion detector, ON or OFF
#!/bin/sh
/home/pi/domoticz/scripts/wemo/wemo_control.sh 10.0.51.183 GETSTATE
Makes the call to Domoticz to switch on and off the switch
#!/bin/sh
curl "http://xxx:[email protected]:8084/json.htm?type=command&param=switchlight&idx=255&switchcmd=On"
sleep 2
curl "http://xxx:[email protected]:8084/json.htm?type=command&param=switchlight&idx=255&switchcmd=Off"
wemo_motion_loop.sh
Simple script to loop every 5 seconds(ish)
#!/bin/sh
max=11
for i in `seq 1 $max`
do
    echo "$i"
now=$(date +"%T")
echo $now
./wemo_motion_main.sh
sleep 5
done
Now running wemo_motion_loop.sh from the command line works...if I dance around in front of the motion sensor for at least 5 seconds, motion is detected, and the status of the dummy switch gets updated.
So I thought, simple...add a cron job, to run every minute, call wemo_motion_loop.sh and we're sorted.
*/1 * * * * /home/pi/domoticz/scripts/wemo/wemo_motion_loop.sh
When I run under cron, the script doesn't work.
I guess I'm being a muppet, and missed something obvious...
Thanks in advance.
Re: Wemo Motion
Posted: Sunday 31 July 2016 1:35
by ben53252642
Don't use cron, use screen
/usr/bin/screen -S WemoMotionMonitor -d -m /home/pi/domoticz/scripts/wemo/wemo_motion_loop.sh
It will run constantly in the background, you can view it by typing screen -x getting the screen session then typing screen -x NAMEOFTHESESSION
You might want to add that into startup so it runs on boot once you have everything setup right.
This may be of interest:
https://github.com/unrelatedlabs/java-wemo-bridge
Also I see no reason why not to try 1 or 2 seconds. :D
Re: Wemo Motion
Posted: Sunday 31 July 2016 13:40
by D5120
Interesting, thanks very much Ben, I'll give them a blast :)
Re: Wemo Motion
Posted: Sunday 31 July 2016 20:00
by ben53252642
I forgot, to detach from a screen session use cntrl a d (press the 3 buttons on the keyboard).
Think of screen like multiple "windows" for linux terminal, those windows remain running even if you disconnect from the terminal session. It's a good way to run programs in the background and on boot.
I have a lot of screen sessions used in this way.
screen 5.png (29.03 KiB) Viewed 1233 times
If I wanted to connect to the KettleBridge session the command I'd use would be: screen -x 13950.KettleBridge
to disconnect back to the main terminal I'd use cntrl a d
