Is there any way to create the user variable in domoticz by lua script ?
UserVariables in scrips
jjdom
- Domoticz version: 3.4834
José
Domoticz raspberry pi
Version 3.4834
Version 3.4834
georgesattali
Re: UserVariables in scrips
yes, here an example :
but beware, that using commandArray, the variable will be created only when the script exits.
otherwise, you may use curl with the same kind of http call.
details here : https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
Bye, GD
ip = '127.0.0.1:8080' -- user:pass@ip:port de domoticz
function UrlEncode(str) -- source : http://lua-users.org/wiki/StringRecipes
if (str) then
str = string.gsub (str, "\n", "\r\n")
str = string.gsub (str, "([^%w %-%_%.%~])",
function (c) return string.format ("%%%02X", string.byte(c)) end)
str = string.gsub (str, " ", "+")
return str
varName = "My Var Name"
if (uservariables[varName] == nil) then
i=1
urlVarName = UrlEncode(varName)
commandArray[i]= { ['OpenURL'] = ip -- create variable
..'/json.htm?type=command¶m=saveuservariable'
..'&vname='..urlVarName
..'&vtype=2'
..'&vvalue='.."0"
jjdom
Hi GD,
Thanks a lot, I will try this asap
José
Version 3.4834
Version 3.4834
jjdom
Hi all
I have tried this one:
and the result in logs is
If I put the url in a local variable, and print it, I get the same result.
is there any issue for this ?
urlVarName = UrlEncode('MonTest')
commandArray[1]= { ['OpenURL'] = ip -- create variable
..'&vtype=2'
..'&vvalue='..'"0"'}Code: Select all
2016-08-02 13:58:44.351 Error: Error opening url: X.X.X.X:Y/json.htm?type=command¶m=saveuservariable&vname=MonTest&vtype=2&vvalue="10"is there any issue for this ?
José
Version 3.4834
Version 3.4834
jjdom
Hi all
My problem is solved.
I'had made a mistake on my IP.
Thanks a lot GD and all others.
José
Version 3.4834
Version 3.4834
