Qubino ZMNHOD1 Flush Shutter DC
Posted: Friday 22 July 2016 20:47
by Varazir
Hello
I have installed a Qubino ZMNHOD1 Flush Shutter DC,
The calibration works fine.
No new devices are showing up.
I tested from the zwave control panel and the up and down works
I see this in the log
2016-07-22 21:23:04.934 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-07-22 21:23:04.938 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2016-07-22 21:23:04.938 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2016-07-22 21:23:04.939 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2016-07-22 21:23:04.939 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-07-22 21:23:04.943 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
2016-07-22 21:23:04.944 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
2016-07-22 21:23:04.944 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: METER, Label: Energy, Instance: 1
2016-07-22 21:23:04.945 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: METER, Label: Power, Instance: 1
I tried to exclude and include it again, still same no devices
2016-07-24 10:38:17.199 OpenZWave: New Node added. HomeID: 3260666225, NodeID: 8 (0x08)
2016-07-24 10:38:17.268 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-07-24 10:38:17.269 (RaZberry) Light/Switch (Level)
2016-07-24 10:38:17.283 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-07-24 10:38:17.284 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2016-07-24 10:38:17.285 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-07-24 10:38:17.291 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: METER, Label: Unknown, Instance: 1
2016-07-24 10:38:17.633 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: METER, Label: Power, Instance: 1
Edit: Got it to work after the exclude and include, I just missed it when I check the devices list at first.
