LUA, dimmer Set Level 6 sets dimmer to 0%
toreandre
Post by toreandre »
Im tying to use a selctor switch to set different dim levels.
But i have some problems.
The "Set Level 6" sets the dimmer to 0%
The "Set Level 73" sets the dimmer to 66%
The "Set Level 26" sets the dimemr to 20%
I can set these dim values manually on the dimmer slider, but not with lua.
if (devicechanged['Effekter barnerom'] == 'Regnbue') then
   commandArray['Effekt 0']='Set Level 6'
elseif (devicechanged['Effekter barnerom'] == 'Rosa flamme 1') then
   commandArray['Effekt 0']='Set Level 20'
elseif (devicechanged['Effekter barnerom'] == 'Rosa flamme 2') then
   commandArray['Effekt 0']='Set Level 40'
elseif (devicechanged['Effekter barnerom'] == 'Alarm') then
   commandArray['Effekt 0']='Set Level 73'
elseif (devicechanged['Effekter barnerom'] == 'Levende lys') then
   commandArray['Effekt 0']='Set Level 26'
