Error, Node047, WARNING: node revived
Posted: Monday 18 July 2016 8:55
Hi there! I need some advice.
I had a FIBARO System FGK101 Door Opening Sensor that stopped working. Now I need to remove it from my list of devices in OpenZWave Control Panel.
There are actually 2 devices that I need to remove. They are listed as follows:
The device is removed and has no battery. When I run the "Has Node Failed" command i get the following in the log:
The status won't change to "Failed" as I would like it to so I can not remove failed devices.
The same goes for node 48. What is the "WARNING: node revived" message trying to tell me and how shall I proceed to delete the 2 ghost devices?
Thanks!!!
Node Id Basic Type Generic Type Product Name Location Value Last Heard Status
47 BR Routing Slave Routing Binary Sensor FIBARO System FGK101 Door Opening Sensor D5 on 09:31:00 CacheLoad (sleeping)
48 BR Routing Slave Routing Binary Sensor FIBARO System FGK101 Door Opening Sensor OLD off 09:31:04 Probe (sleeping)Code: Select all
2016-07-18 08:50:55.106 Error, Node047, WARNING: node revived
2016-07-18 08:50:55.106 Always,
2016-07-18 08:50:55.106 Always, Dumping queued log messages
2016-07-18 08:50:55.106 Always, End of queued log message dump
Thanks!!!
