vESPrino - (@Indiegogo) quickly pimp your Domoticz
Posted: Tuesday 12 July 2016 22:07
Hi Guys,
You may be interested in this device: vESPrino
https://www.indiegogo.com/projects/vesp ... x/10721175#/
Just launched the campaign. Have a have a look on the video
Perks start at 5-6 Eur
It is a small USB Powered device, that has Button and RGB Led. Via Serial Port you can configure it to connect to Domoticz and either trigger event with the button, or led the LED shine some color.
There is also a variety of sensors that can be easily plugged in - w/o wires- E.g. Gesture or RFID sensor. Or some display to which you can send messages from Domotica. Also there are the standard LUX and Temperature sensors, and few others.
The primary goal is for people to quickly jump into developing IOT apps, but i believe it has also potential for Home automation scenarios.
If there is interest from the community i would also add native support for Domoticz, so that only some general parameters like Host, device id will need to be entered, and all the rest is done by the firmware
Regards, Vladimir
Regards, Vladimir
