Soil moisture graph
Posted: Tuesday 12 July 2016 13:44
by insippo
I use mysensors soil moisture driver. All is ok but domoticz put graph to temperature menu and write to graph window Temperature last 7days, Temperature last month, and year. How to change this?
Re: Soil moisture graph
Posted: Thursday 14 July 2016 8:35
by gizmocuz
Your using a 100% copy of the MySensors soil example? Or are you also sending other sensors ?
if it is a copy, it should work... i think... i do not find it a good sample...
How about you change the presentation from S_HUM to S_MOISTURE ? that should give you a better sensor i suppose
Posted: Thursday 14 July 2016 9:15
by insippo
Yes.100% Mysensors example. Only soil moisture. Where i change S_HUM to S_MOISTURE ? In mysensors arduino sketch ? Oh. Too many questions.
Posted: Thursday 14 July 2016 9:50
by trixwood
Yes in the sketch.
Posted: Thursday 14 July 2016 11:07
by insippo
Okay. I change after work.
Posted: Thursday 14 July 2016 12:21
by insippo
#include <SPI.h>
#include <MySensor.h>
#define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
#define CHILD_ID_BATTERY 0
#define SLEEP_TIME 600000 // Sleep time between reads (in milliseconds)
#define STABILIZATION_TIME 500 // Let the sensor stabilize 0.5 seconds before reading
#define BATTERY_FULL 3000 // 3,000 millivolts when battery is full (assuming 2xAA)
#define BATTERY_ZERO 1700 // 1,700 millivolts when battery is empty (reqires blown brownout detection fuse, use 2,800 otherwise)
// This sketch assumes power from 2xAA on Vcc (not RAW). Remove the power led and the voltage regulator for better battery life.
// Sensors shall be connected to GND and their analog pin. Throw away the middle chip, just use the pitchfork.
// Number of analog pins for each Arduino model can be seen at https://www.arduino.cc/en/Products/Compare
// A5 and A6 on most Arduinos cannot be used because they don't have internal pullups
const int SENSORS[] = {A0, A1, A2, A3}; // Remove the pins that you don't want to use
#define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
long oldvoltage = 0;
MySensor gw;
MyMessage moisture_messages[N_ELEMENTS(SENSORS)];
MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
void setup()
gw.begin();
gw.sendSketchInfo("Plants moisture w bat", "1.2");
gw.present(CHILD_ID_BATTERY, S_CUSTOM);
for (int sensor = 0; sensor < N_ELEMENTS(SENSORS); sensor++) {
moisture_messages[sensor].sensor = sensor + 1; // Battery uses child ID 0 so sensors start at 1
moisture_messages[sensor].type = V_HUM;
delay(250);
gw.present(sensor + 1, S_HUM);
for (int i = 0; i < N_ELEMENTS(SENSORS); i++) {
pinMode(SENSORS, OUTPUT);
digitalWrite(SENSORS, LOW);
void loop()
pinMode(SENSORS[sensor], INPUT_PULLUP); // "Power on" the sensor and activate the internal pullup resistor
analogRead(SENSORS[sensor]); // Read once to let the ADC capacitor start charging
gw.sleep(STABILIZATION_TIME);
int moistureLevel = (1023 - analogRead(SENSORS[sensor])) / 10.23;
// Turn off the sensor to conserve battery and minimize corrosion
pinMode(SENSORS[sensor], OUTPUT);
digitalWrite(SENSORS[sensor], LOW);
gw.send(moisture_messages[sensor].set(moistureLevel));
long voltage = readVcc();
if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
gw.send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts and set wants volts and how many decimals (3 in our case)
gw.sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
oldvoltage = voltage;
gw.sleep(SLEEP_TIME);
long readVcc()
// From http://provideyourown.com/2012/secret-a ... y-voltage/
// Read 1.1V reference against AVcc
// set the reference to Vcc and the measurement to the internal 1.1V reference
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
ADMUX = _BV(MUX5) | _BV(MUX0);
#elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
ADMUX = _BV(MUX3) | _BV(MUX2);
#else
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA, ADSC)); // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
uint8_t high = ADCH; // unlocks both
long result = (high << 8) | low;
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
return result; // Vcc in millivolts
Posted: Thursday 14 July 2016 12:22
by insippo
Here is V_HUM and S_HUM. What exactly needed replaced ?
Posted: Thursday 14 July 2016 20:11
by trixwood
I would try the S_HUM as gizmocuz suggested. If that don't work change the other one too. I have no Idea.
You got this one from: https://forum.mysensors.org/topic/2147/ ... /24?page=1
Cuz the official one looks very different.
https://github.com/mysensors/MySensors/ ... Sensor.ino
Well, all the better, i am building that one too! at least if the last parts arrive from the hung dynasty.
The only thing I want to change is sleeptime/delay vs rate of change for smoother graphs. But that probably will reduce battery life at least half. Brainstorming away...
