[LIB] Variable file
sploutchi
[LIB] Variable file
Post by sploutchi »
Hi all !
I am trying to make a variable file with all my device.
In this file, I try to make a function to print all of them... but I'm stuck on this part.
You will find after an excerpt from my file variable.lua :
-- ------- Variables ------------
local V={};
-- Switch ON/OFF
V.prise_Cuisine = ''
V.prise_Chambre = ''
V.prise_Salon = ''
-- Les volets
V.les_volets = {};
V.les_volets[1] = {volet="Volets Salon", fenetre = "Fenêtre salon", temperature="salon", idx="192"}
-- Les chauffages avec fil pilote
V.les_chauffages = {};
V.les_chauffages[1] = {chauffage="Chauffage Chambre", piece = "Chambre"}
V.les_chauffages[2] = {chauffage="Chauffage Salon", piece = "Salon"}
V.les_chauffages[3] = {chauffage="Chauffage SDB", piece = "Salle de Bain"}
-- Les volets
function V.afficher_variables ()
	for a,b in pairs(V) do
		print ("==> a : '".. a .. "'");
		print ("type : "..type(b));
		if (type(b) == "table") then
			for x,y in pairs(b) do
				print ("====> x : '".. x .. "'");
				print ("type : "..type(y));
				if (type(y) == "table") then
					for c,d in pairs(b) do
						print ("=======> c : '".. c .. "'");
						print ("=======> d : '".. d .. "'");
				elseif (type(y) == "string") then
					print ("====> y : '".. y .. "'");
		elseif (type(b) == "string") then
			print ("==> b : '".. b .. "'");
	return true;
return V;
And that's what the function afficher_variables print :
2016-07-12 12:02:06.771 LUA: ==> a : 'thermostat_chambre_amis'
2016-07-12 12:02:06.771 LUA: type : string
2016-07-12 12:02:06.772 LUA: ==> b : 'THCAMIS'
2016-07-12 12:02:06.772 LUA: ==> a : 'les_volets'
2016-07-12 12:02:06.772 LUA: type : table
2016-07-12 12:02:06.772 LUA: ====> x : '1'
2016-07-12 12:02:06.773 LUA: type : table
2016-07-12 12:02:06.773 LUA: =======> c : '1'
2016-07-12 12:02:06.774 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_TEST.lua: ./variables.lua:58: attempt to concatenate local 'd' (a table value)
Can you help me ?
georgesattali
Re: [LIB] Variable file
Post by georgesattali »
is your script incomplete ?
where does 'thermostat_chambre_amis' come from, I can't see it in the code ?
Maybe, if you write on Windows and then copy to Linux there's a problem. check that maybe, or at least, put the complete script on the forum.
Also, probably the line
may be wrong, do you mean
for c,d in pairs(y) do
See U, GD
