Philips Hue White group shows as RGBW instead of as a dimmer
Posted: Monday 11 July 2016 9:15
by anandus
I have Philips Hue White lamps. Seperately the appear as dimmer switches (Lighting 2/AC) in Domoticz, as they should be.
But as a group (called 'room' in Hue) they appear as a RGBW dimmer switch (Lighting Limitless/Applamp/RGBW), which is silly, as it are just dimmable LED-lights.
How to change the RGBW-switch to a normal (non-RGB) dimmer switch?
I tried selecting 'white' instead of 'RGB' next to the colour palette in the switch edit screen, but that doesn't work.
Does anyone know how to change it?
Re: Philips Hue White group shows as RGBW instead of as a dimmer
Posted: Monday 11 July 2016 10:04
by trixwood
And the group are all white lamps? If you added one or more rgbw lights the group will be that.
If they are all white lamps, it's a bug and you should post it here: https://github.com/domoticz/domoticz/issues
To you question of change. Do not think you can change that, it's not a virtual sensor. I could be wrong, can't check, no domoticz, it crashed :?
Posted: Monday 11 July 2016 10:40
by anandus
Yes, it are all White lamps. In the Hue-app itself the group also shows just a slider
Posted: Thursday 14 July 2016 0:12
by trixwood
best thing to do is open an issue on Github https://github.com/domoticz/domoticz/issues and describe it there
