Domo with Nginx
Posted: Saturday 09 July 2016 10:42
After some strange behavoir on mine domo server i want to secure this .
So followed the Nginx wiki ( http://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup )
But when i instert to nginx.conf
the service won't start anymore ?
nginx -t -c /etc/nginx/nginx.conf
Insert would be like :
Wen deleted this everything is workingfine .
http {
client_header_buffer_size 32k;
large_client_header_buffers 16 32k;
}Code: Select all
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.Code: Select all
failed (13: Permission denied)
2016/07/09 10:50:55 [warn] 11020#11020: the "user" directive makes sense only if the master process runs with super-user privileges, ignored in /etc/nginx/nginx.conf:1
2016/07/09 10:50:55 [emerg] 11020#11020: unknown directive "...." in /etc/nginx/nginx.conf:13
nginx: configuration file /etc/nginx/nginx.conf test failed
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
