Problem with devicechanged
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
I've got a strange behavior.
I have a Virtual Hardware named "Lux" of type Lux / sub type Lux.
I update it without problem with
        commandArray[1] = {['UpdateDevice'] = myidx..'|0|'..'xxx'}
But in a script_device_cc.lua I can't detect the change of it.
This line has no effect :
 if devicechanged['Lux']
any clue ?
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
jvdz
Domoticz version: 4.107
Re: Problem with devicechanged
Post by jvdz »
Try adding this to a script_device_xx.lua script to list the devices that are update and then run the logic that updates your LUX device:
-- List devices that changed
for i, v in pairs(devicechanged) do
	print("Device =>"..i.."   status:"..v)
This should tell you what is triggered if any.
Jos
jmleglise
Post by jmleglise »
Thanks, that confirmes :
Custom sensor, and virtual Lux sensor don't rise a "devicechanged".
However , temperature, and other, percentage dummy work fine.
I've tested on 3.51xx and 3.52xx
How is it possible ?!?
KMTronic USB relay
