Hello
I´m using Domoticz from a while and I can't figure out what happened with my domoticz installation.
Some times the lights icons change their status from off to on or from on to off without touching anything. but when changed the state (for example a light switch from off to on) the light realy don't turn on, only seen different status inside my phone apps or the webpage.
The switch hardware are Aeotec Micro Smart Energy G2
I see this in the log
2016-07-05 20:41:25 Off
2016-07-05 20:40:38 On
2016-07-05 20:21:31 On
2016-07-05 20:19:27 On
2016-07-05 20:12:13 On
Please I need help because I love this domotic solution
I´m running V3.5276 but this problem happened with other versions too
regards
Light Switch change their status random
pluggin
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
pluggin
Re: Light Switch change their status random
More info...
Like you see after an Off command immediately sent an On command without user intervention.
The icon change like you see in the picture
But is not ON, there is no consuming energy
pluggin
Nobody have this problem? Sorry, but a don´t know where to start looking to resolve it
Lemme
- Domoticz version: Dev
Hi Plugin
I have experienced the same problem yesterday - several times. In my setup, I have created some MySensors nodes. And I have made a Blockely script that handles the logic. But suddenly the relays in the nodes switches state, without any user interaction.
As part of problem solving, I shut down Domoticz. The idea was to isolate the problem to be either node or Domoticz related. Until now, the relay did not swiths state by it's own. I will now try to start Domoticz again, to see if the problem comes back.
Br
Lemme
Br
Lemme
