Notifymyandroid results in error, although key is OK
Posted: Monday 04 July 2016 23:09
by marin849
I have had the problem for a few months that NMA notification doesn't work so decided to check today.
I have created a new API-key, and tested it with the verify-url, then I sent a test message as an URL-string through the web-browser to check that it works. It does!
Then I tried this on the pi running Domoticz.
pi@pi2 ~ $ wget "https://www.notifymyandroid.com/publicapi/notify?apikey=yesmykeywashere&application=%22Domoticz%22&message=%22test%22&event=%22testevent%22&description=%22inget%22"
That works as well!
Problem is in Domoticz I only get "Problem sending, check API-key" when I test the notification, and in the log it only says:
2016-07-04 23:02:51.080 Error: NMA:
2016-07-04 23:02:51.080 Error: Notification sent (nma) => Failed
Verbose logging is enabled.
It is difficult too see what is wrong, as the error message is blank. I have Domoticz 3.5274. Any Ideas?
Re: Notifymyandroid results in error, although key is OK
Posted: Friday 15 July 2016 0:39
by marin849
Can anyone confirm that their NMA-notification is working?
Posted: Friday 08 September 2017 12:37
by DomoOr1981
I too, have the same problem and I'am curious how other boardmembers realized their
Notifications (through NMA?).
This verify-test went fine (of course
<my-api-key> was replaced by my own 48-char-api-key).
https://www.notifymyandroid.com/publica ... my-api-key>
My Browser returned:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<nma>
<success code="200" remaining="995" resettimer="30"/>
</nma>
Also, this notify-test went fine.
https://www.notifymyandroid.com/publica ... n=DomoDesc
<nma>
<success code="200" remaining="996" resettimer="32"/>
</nma>
And a little later this "popupped" on my phone:
- Screenshot_NMA_Test.jpg (10.97 KiB) Viewed 5111 times
But I cannot get it to work in Domoticz. The testbutton in Domoticz result in (the log):
2017-09-08 11:46:29.122 Error: NMA:
2017-09-08 11:46:29.123 Error: Notification sent (nma) => Failed
2017-09-08 11:46:29.161 Active notification Subsystems: nma (1/12)
"Who o who" has got the solution?
Thank you for your help.
Posted: Tuesday 12 September 2017 13:57
by DomoOr1981
At last everything works fine now on my "RPi 1 B+" after a fresh installation with this older image: "
2017-07-05-raspbian-jessie-lite.img" (my starting-trials were with different versions of Raspbian Stretch Lite).
Posted: Tuesday 12 September 2017 14:21
by SweetPants
If you read the forum, you would have seen there are some problems with the latest Beta's concerning HTTP(s) mainly related using Stretch
Posted: Sunday 17 September 2017 14:11
by DomoOr1981
I can't read the whole forum the whole time
So, to which topic(s) are you referring?
Posted: Monday 13 November 2017 17:17
by marin849
I just did a new install with Raspbian stretch lite and I have the same exact problem in both the new installation and the old installation, running Raspbian Wheezy. I am also curious which thread that is mentioned.
Posted: Wednesday 11 April 2018 19:28
by Denny64
