Reset/turn a switch/PIR off?
Posted: Monday 04 July 2016 11:00
Sometimes Domoticz doesn't always pick up a change in a door sensor or PIR etc.
I know this isn't Domoticz fault and down to the hardware and these things happen etc. I played with positioning etc. etc. but looking for an override so for example a magnetic door sensor says it's 'open' but quite clearly the door isn't and the I'm closed signal was never received or a PIR sensor that was detecting movement and Domoticz never sees the 'off' signal sent is there way to override this?
At the moment to counter this I tend to have go trigger the sensor so Domoticz sees the open then closed signal but I can't do this if I'm away etc. and the neighbours have brought my mail in or whatever.
