Help to convert code for different sensor
Posted: Sunday 03 July 2016 17:22
by Madasahatter
Can anyone please help me change this code from DHT-22 sensor support to one wire sensor either TMP36 Sensor or DS18B20 Sensor support
Temperature and humidity sensor / sender
Uses a DHT series temperature and humidity sensor and an ASK RF transmitter
Requires the following Arduino libraries to be installed in the libraries directory:
- DHT from https://github.com/markruys/arduino-DHT
- WT450Sender from https://github.com/GraemeWieden/WT450Sender
#include <DHT.h>
#include <WT450Sender.h>
// set up the hardware pins
byte sensorPin = 3; // digital pin for DHT sensor
byte txPin = 4; // digital pin for RF transmitter
byte ledPin = 13; // digital pin for LED
// define our desired house and channel codes
byte houseCode = 15; // from 1 to 15
byte channelCode = 4; // from 1 to 4
DHT sensor; // create the sensor object
WT450Sender sender; // create the sender object
void setup()
sensor.setup(sensorPin);
sender.setup(txPin, houseCode, channelCode);
pinMode(ledPin, OUTPUT);
Serial.begin(9600);
Serial.println("Temperature and Humidity Sender");
void loop()
delay(20000); // send every 20 seconds
double t = sensor.getTemperature();
double h = sensor.getHumidity();
// output readings to the serial monitor
Serial.print(t);
Serial.print("C ");
Serial.print(h);
Serial.println("%");
sender.send(h, t); // send the sensor readings
blinkLed(); // flash the led
void blinkLed()
digitalWrite(ledPin, HIGH);
delay(30);
digitalWrite(ledPin, LOW);
thanks
