need help
blocky script not working
- jvdz
- Domoticz version: 4.107
Re: blocky script not working
There is a logic error: Time can never be bigger than SunSet AND at the same time smaller than SunRise! This is impossible.
Jos
Jos
trixwood
So it should be "or" instead of "and"
making
door sensor = open and (Time > Sunset or Time < Sunrise)
btw on a sidenote when using the abstractions time and sunset, from a logic point of view it is totally correct to use "AND". Time does not reset at 00:00 (this is not groundhog day) just like 1+99 does not reset to 00 but result in 100, and in case of time representation the 1 in 100 is a brand new day!
That the abstraction translation and representation to actual numbers (like sunset to 06:34 AM, time to 03:22 AM stripping the day carrier) make things difficult and the ambiguous of how time is defined more so if you are not a programmer: does time include days, months and years or time for just one day. There in lies the problem.
Logically speaking: Sun is Down = Time < Sunrise and Time > Sunset
But yeah then time, it's all bout the forgotten days...
Time, abstractions and logic, all funny stuff...
making
Try to make you're blocky script like this :
If time is > then sunset and doorsensor = open
Set staircase lights = on for 1 minute
Else if
If time is > then sunrise and doorsensor = open
Set staircase lights = off
Verstuurd vanaf mijn SM-G935F met Tapatalk
Else if
trixwood
That only make more code... and it will not work in the morning :-/
changing and to or is enough...
Just use:
if door sensor = open and (Time > Sunset or Time < Sunrise)
do set etc...
So you can enjoy your light for a minute when the sun is down and the door opens!
Just use:
do set etc...
