Hello ,
I have worked 3 days on domoticz to remote my SOMFY blinds with RFLINK V42 :
1 - Command in terminal work very well :
pi@raspberrypi ~ $ echo "10;RTS;0100F2;0;DOWN;" > /dev/ttyACM0
pi@raspberrypi ~ $ echo "10;RTS;0100F2;0;STOP;" > /dev/ttyACM0
pi@raspberrypi ~ $ echo "10;RTS;0100F2;0;UP;" > /dev/ttyACM0
2 - Configuration switch : manual
Matériel: RFLINK
Nom du périphérique: Bureau
Type d'interrupteur: Venetian blind EU
Type: RFY
ID: 01 00 F2
Code d'unité: 1
When I push blind button , an error came : Error sending switch command, check device/hardware !
3 - For more information .
My temperature sensor work with DomoticZ
My Radio switch Workst Too.
Domoticz V2.4025
RFLINK V42
RASPBERRY PI V1
4 - Question :
My blinds programming is it OK ?
I have run many post on forum but no results on my Error can you help me ?
Blinds : Error sending switch command, check device/hardware !
octopuss83
Best Regards
------========= Octopuss =======---------
- Stuntteam
Re: Blinds : Error sending switch command, check device/hardware !
remove the device you created and do the following:
Go to settings,hardware and look for the RFLink device
behind the device name there will be "create rflink devices" button. (If not then update your Domoticz to a more recent beta version)
Press this button, in the popup enter:
20;A9;RTS;ID=0100F2;SWITCH=00;CMD=STOP;
and press OK
then go to settings,devices
press the green arrow and give your device a name
next go to switches and modify to a ventian blind
and press OK
