Is it possible to delete devices with Json?
Something like -
/json.htm?type=command¶m=deletedevice&idx=IDX
This doesn't work, returning an ERR status
Delete device with Json?
- Westcott
- Egregius
- Domoticz version: v2024.7
Re: Delete device with Json?
Think it should be something like:
That's the url that's called when you edit/remove a device.
Or
when deleting from the devices view.
Both urls tested and confirmed as working.
http://192.168.0.10:8084/json.htm?type=setused&idx=535&name=test&description=&used=false
Or
http://192.168.0.10:8084/json.htm?type=deletedevice&idx=535
- Westcott
Hi Egregius,
Thanks for the quick answer!
Yes, your 2nd example works for me, even simpler than I guessed.
Perhaps it should be documented in the Wiki?
I'm going to use it to delete spurious unused devices added by RFX and RFlink.
- Egregius
Be carefull...
I would just leave them there or disable new sensors.
