Notification
Posted: Thursday 30 June 2016 13:18
by BertB
I was experimenting with getting notifications from my RPI Domoticz server on my android phone, when I noticed that they also arrive on the Domotica app. Great, but ... it only seems to work when all notification options are checked, so I also get an email.
Is this intended?
Where can I find notification history?
Greets, Bert
Re: Notification
Posted: Tuesday 12 July 2016 14:26
by marcelk
I'm trying to figure out how I can have Domoticz (I run it on a Windows system and a pi) send notifications to the Domoticz-Lite app (on Android) so I hope you at least explain how you got this to work?
Re: Notification
Posted: Tuesday 12 July 2016 18:16
by BertB
I think you need the Pro Version to het notificaties. Did you enable the notificaties in the app by allowing it in the settings?
Re: Notification
Posted: Friday 15 July 2016 22:21
by marcelk
I got it working but like you mentioned I also have to select every notification method in the switch-config. I did not configure the notification options in setting so I don't get them via email or pushbullet for example but only via the Domoticz Lite app.
It would be nice if there was an option to select the Domoticz App as Notification destination instead of all the other options.
Re: Notification
Posted: Thursday 13 October 2016 19:46
by Andrex
Marcelk would you like to share with us how you did it?
Re: Notification
Posted: Sunday 11 December 2016 17:01
by dobber
marcelk wrote:I got it working but like you mentioned I also have to select every notification method in the switch-config. I did not configure the notification options in setting so I don't get them via email or pushbullet for example but only via the Domoticz Lite app.
I'm having the same issue. All need to be selected for notifications to be sent to android app.
I tried every single option by itself, but no go.
Re: Notification
Posted: Tuesday 27 December 2016 18:47
by delfisastre
I have the same problem! when all the notifications are ON. (email, pushbullet...) everythink works ok, but if i try all except email. The notifications are not send to my mobile.
Re: Notification
Posted: Monday 27 February 2017 13:33
by paralight
hi
i've got notifications problems too. Sometimes i get notifications on phone , sometimes not. very annoying.. all notifications are checked on domoticz. logs works fine , so it's not a captors issue.
Re: Notification
Posted: Sunday 06 January 2019 10:04
by marmachine
I have just set things up... haven't had time to check this out since notifymyandroid has disappeared, but my result is that i only have to check "GCM" as notification system, ofcourse i can also check others like email, but not required to receive push notifications in my app. You might want to check if you have the option activated in your app settings. By the way; i have the full (payed) Domoticz Android app (NOT Domoticz lite!) and currently running Domoticz version: 4.9962 on a Pi.
