S0PCM-5 with inductive sensor
Posted: Tuesday 28 June 2016 9:37
by marin849
I cant find any electrical specifications on the S0meter S0PCM-5.
I need to connect an inductive sensor for my water meter, and a IR-led for my electrical meter.
Is the S0-inputs pulled up internally by the S0PCM? To which voltage? What is the maximum permissible voltage at the inputs?
Re: S0PCM-5 with inductive sensor
Posted: Tuesday 28 June 2016 10:43
by Toulon7559
Suggested to ask the supplier of S0PCM more direct at http://www.smartmeterdashboard.nl/contact
Posted: Friday 15 July 2016 0:35
by marin849
Received it. It has 5V with some 50KOhm reistance (or so..).
Best method is to use an optocoupler.
