Help wanted with LUA/dzVents
Posted: Monday 27 June 2016 12:57
by elmortero
Hi everyone,
I want to create a script set all smoke detectors I have to 'Panic' using Lua/dzvents.
More than help with actual writing I would like some ideas/feedback on how the logic should be handled.
I want to use a wild-card for the triggering 'smd*' but I surely don't want to create a loop when activating the 'Panic' modes which will then trigger the script again, since at that moment *all* detectors will have a changed status to 'panic' and so on..
I have no scripting/programming experience and only started with Lua a little while ago because Blockly does not serve my needs.
Thanks in advance,
Olivier
PS: I know I can write separate script for each detector and the trigger all but that one to avoid the loop, but if possible I would like to avoid having a multitude of scripts.
Re: Help wanted with LUA/dzVents
Posted: Monday 27 June 2016 12:59
by dannybloe
What would cause a loop then? What is the exact chain of events? One detector detects smoke and then all other detectors should start to panic?
Posted: Monday 27 June 2016 14:20
by elmortero
dannybloe wrote: One detector detects smoke and then all other detectors should start to panic?
That is indeed what I want. If smoke is detected, warning everybody in the house by activating the alarm of all detectors.
But wouldn't this trigger the script again, and again...?
Posted: Monday 27 June 2016 14:45
by dannybloe
I'd do something like this. By checking if the state isn't already Panic only then you set it to Panic (this prevents the looping).
local detectors = {
['smokeDetector1'] = true,
['smokeDetector2'] = true,
['smokeDetector3'] = true
active = true,
'smokeDetector*'
execute = function(domoticz, smokeDetector)
if (smokeDetector.status == 'Panic') then
-- filter all devices based on the detectors list above
-- and only those that aren't already in Panic mode
domoticz.devices.filter(function(device)
-- return true for non-panic devices and with the proper name
return detectors[device.name] == true and device.state ~= 'Panic'
end).forEach(function(detector)
-- set to panic
detector.setState('Panic')
end)
I don't have smoke detectors myself so it could be that this doesn't work
Of course there are many ways that lead to Rome...
Or if you want to make it less generic:
active = true,
'smokeDetector1',
'smokeDetector2,'
'smokeDetector3'
if (domoticz.devices['smokeDetector1'].state ~= 'Panic') then
domoticz.devices['smokeDetector1'].setState('Panic')
if (domoticz.devices['smokeDetector2'].state ~= 'Panic') then
domoticz.devices['smokeDetector2'].setState('Panic')
if (domoticz.devices['smokeDetector3'].state ~= 'Panic') then
domoticz.devices['smokeDetector3'].setState('Panic')
Posted: Monday 27 June 2016 14:56
by elmortero
Ok Danny, this is a big help.
Looks good, as soon as I am alone in the house I can do a test (my partner would kick me out of the house if I test this while she is home (too loud).
Actually my biggest mistake was forgetting that you can put several devices in the on = { } part and that I would have to have a script for each detector.
I knew this, just did not think about it.
BTW: I really like what you have created with dzVents, makes scripting life so much easier.
Posted: Monday 27 June 2016 15:01
by dannybloe
elmortero wrote:Ok Danny, this is a big help.
I'm not exactly sure if setState('Panic') is the way to go though. Let me know if it works.
Posted: Monday 27 June 2016 15:42
by elmortero
It makes sense that way, but if it is not, I'll use the json approach, or create scene and activate that one.
Posted: Monday 27 June 2016 15:47
by dannybloe
That should not be needed. As far as I know you can send all commands using dzVents without json. If not then I'll add it.
Posted: Friday 01 July 2016 16:54
by elmortero
Hi Danny,
Tried it today, but it failed.
Seems to be ineed something with the .setState('Panic') because when I replace that with a virtual switch it works.
In this topic
http://www.domoticz.com/forum/viewtopic ... son#p44652
Eduard said it works with /json.htm?type=command¶m=switchlight&idx=3&switchcmd=On
So I guess instead of setState('Panic') I should use switchOn()
Hope to find some alone time this weekend to test but I feel confident that this will be it.
Update: just tried it, not working, no error messages.
Posted: Sunday 03 July 2016 12:59
by dannybloe
Strange.I couldn't find much information regarding this kind of 'switch' It should be possible.
Posted: Tuesday 05 July 2016 12:32
by elmortero
It is odd indeed.
As soon as I can I will do some more tests.
For now, in order to have this working, I will have to use Blockly (thought I'd seen the last of that
Posted: Tuesday 05 July 2016 12:40
by dannybloe
Would be interesting to know what Blockly sends to Domoticz (internally) as the value.
Posted: Friday 05 August 2016 9:24
by elmortero
Finally been able to test.
The switchOn() does the trick, as for the check to the current status, 'Panic' is not how check.
This seems to work:
active = true,
'smd-bedroom',
'smd-hall',
'smd-guest',
'smd-salon',
'smd-kitchen'
execute = function(domoticz)
local bedroom = domoticz.devices['smd-bedroom']
local hall = domoticz.devices['smd-hall']
local guest = domoticz.devices['smd-guest']
local salon = domoticz.devices['smd-salon']
local kitchen = domoticz.devices['smd-kitchen']
if (bedroom.changed and bedroom.status == 'On')
or (hall.changed and hall.status == 'On')
or (guest.changed and guest.status == 'On')
or (salon.changed and salon.status == 'On')
or (kitchen.changed and kitchen.status == 'On')
then
if kitchen.state == 'Off' then
kitchen.switchOn()
if (hall.state ~= 'On') then
hall.switchOn()
if (guest.state ~= 'On') then
guest.switchOn()
if (salon.state ~= 'On') then
salon.switchOn()
if (bedroom.state ~= 'On') then
bedroom.switchOn()
--- end
Thanks a lot for the support
Posted: Friday 05 August 2016 9:35
by dannybloe
Great. Nice to see how the code is so much more readable than without dzVents. That was the main purpose of making it.
Posted: Friday 05 August 2016 9:43
by elmortero
That is why I like it.
I have no coding experience and I learn from examples (that is why I am sometimes lost in manuals..and ask for help).
So when I had to go from Blockly to Lua I was hesitating. But then just after that I you came with dzvents and I liked the posibilities (but had to overcome my resitance to start learning that)
Very glad you put the effort into making it and really grateful.
With the smokedetector thing solved I have everything converted to dzVents scripts.
