Themes not loading
Posted: Friday 24 June 2016 20:19
by mvzut
Since a month or so (always on latest beta) I keep seeing the same theme no matter which I select. I tried emptying caches etc. but to no avail. I have this problem with all browsers that I us: (mobile) Safari, Chrome and Edge. Any tips?
Re: Themes not loading
Posted: Sunday 26 June 2016 13:12
by gizmocuz
Open your browsers developer console and goto the network tab
then change the theme, does it report any issues here?
Posted: Monday 27 June 2016 14:53
by mvzut
I'm not so familiar with the developer console, so don't know what to look for in the network tab. No obvious error messages though.
I did succeed in loading the new theme by clearing the cache another few times and hitting the reload button. Seems I have to do that every time I load a new theme!? In the past I can't remember that this was neccessary. Is there anything that can be done about this?
Posted: Monday 27 June 2016 18:00
by gizmocuz
Do you also have this problem with the stock themes, like the simple-gray theme ?
Posted: Tuesday 23 August 2016 17:11
by leecollings
For what it's worth, I have the same issue, it's almost as though the cache doesn't refresh, and the same theme is stuck 'ON'.
Posted: Tuesday 23 August 2016 18:42
by bdormael
Same Issue here
Posted: Thursday 01 September 2016 12:21
by Sergio
Chrome showing:
Use of the Application Cache is deprecated on insecure origins. Support will be removed in the future. You should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
/#/Dashboard:1 Document was loaded from Application Cache with manifest http://192.168.11.245/html5.appcache
/#/Dashboard:1 Application Cache Checking event
/#/Dashboard:1 Application Cache NoUpdate event
jquery-1.12.0.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Entering the page through https showed for a sec. a red message telling somethig like "...cache manifest loading failed..."
I don't know if it's related.
EDIT: Gocha!
"Browser cache refresh failed. Manifest fetch failed (9). https://192.168.1.10/html5.appcache"
9 might indicate a certificate error. For local accessing it would be better to not use a certificate.
Posted: Thursday 01 September 2016 12:49
by OCB73
I had the same problem (cache manifest) using firefox. When i cleared cache and offline-data in firefox, themes were loading.
Since i wired my raspi instead of using wlan, problem is gone. Maybe it helps someone.
Oliver
Posted: Thursday 01 September 2016 13:45
by Sergio
The connection method shouldn't make a difference while you have a good network configuration, both should be the same.
I had so many problems with web page catching on my application in the past, it's not an easy or nice thing to work on.
Enviado desde mi A0001 mediante Tapatalk
