Resolved: Problem with Louvolite via Domoticz - works via RFXmngr
Posted: Thursday 23 June 2016 17:08
Having some difficulties adding a Louvolite blind.
RFXCom433e with 1005 firmwares. I have to install the Type2 firmware in order to sniff the protocol, this shows up as
BLINDS1 - Safy/Hasta New/RollerTrol
ID2-3 is A2A6
Unit ID is 1
From RFXMngr in Windows it works fully, open, stop and close.
If I then flash the firmware back to EXT2 (required to enable communication with some other Somfy RTS controllers), it still works fine in Windows via RFXmngr, since I now know the codes.
When I try to add this device in Domoticz, as a manual switch, BLINDS0 or BLINDS1 are not available options. I have tried it with BOTH ext2 and Type2 firmwares on the RFXCom, with reboots in between.
Any advice or help greatly appreciated, it's SO close to working, but fallen at the final hurdle!
Thanks in advance.
ID2-3 is A2A6
Unit ID is 1
Thanks in advance.
