Update status only
Posted: Tuesday 21 June 2016 1:27
by JustME125
I am using two kaku switches to control the lights on the nightstand. I can control these switches through some kaku transmitters which are coupled with the switches directly and through domoticz of course. I have this direct coupling in place on purpose as I want to be able to control my lights even when the server crashes. Now, when I use the transmitter to switch the lights, domoticz has no clue the switch has been activated manually which is a bad thing for automation. I can't let domoticz listen to the transmitter and update the switch as that would cause a double switch on action (once by the kaku transmitter and one by domoticz receiving the on signal and switching the switch only to update the status). Well okay, I could be done like this but it is not exactly elegant right?
Is there a way to update the status in domoticz when the transmitter is used without switching from domoticz?
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
