Recently I have swapped a KAKU dimmer for a Fibaro dimmer 2 in our living room. Controlling the dimmer from the domoticz dashboard works fine and I can also use this dimmer in various scenes. So far so good.
Just like in the past I want to be able to control this dimmer with a remote. I'm still using quite some KAKU switches so I have a KAKU remote type AYCT-102 for this purpose. I'd like to use it for the control of the Fibaro dimmer and I'm wondering if someone has ever done this and can please help me with some guidelines how to setup in Domoticz.
Thanks in advance.
How can I use a KAKU remote AYCT-102 to dim Fibaro dimmer 2?
TakeAway
- Domoticz version: 3.7722
Re: How can I use a KAKU remote AYCT-102 to dim Fibaro dimmer 2?
I would like to know this too. As i switched the kaku/coco too, except i would like to switch the dimmer on and of with the kaku AWST-8802 double wall switch.
Raspberry Pi 3 - Domoticz 3.7722 - Aeon Labs Z-Stick GEN5 - RFXcom version: Ext/1012- Logitech Harmony Elite - Homebridge - Fibaro FGMS-001-ZW5 - Fibaro FGDW-002-01 - KAKU stuff.
- Egregius
- Domoticz version: v2024.7
In pass2php that would be like this:
Every push would lower/raise by 5%
<?php
$stat=apcu_fetch('sdimmer');
if($status=='On'){
if($stat!='Off')$level=ceil($stat*1.05);
else $level=1;
sl($item,$level);
}else{
$level=floor($stat*0.95);
sl($item,$level);
TakeAway
I have to look into pass2php, never used it before. I assume this would also be possible with blockly?
- Egregius
As far as I know you can't do calculations in blockly.
You could however set it in a bunche of if/elseif blocks.
TakeAway
Got it working in a simple blockly.
Thx Egregius for your suggestions.
Ron
- Domoticz version: 2.2284
Can you post a screenprint of your Blocky event?
