lua user variable number in email
tiga
Post by tiga »
a have made 2 micro switches in my mailbox.
one for when the mailman puts something in, and one if i open it to empty it.
i have a counter in the lua script that counts the times the mailman puts something in.
and when i open the mailbox it resets the counter.
i completely "stole" the lua script becouse i am a biginner and i can modify a little but cant create my own.
i created a uservariable that counts the amount of mail
i receive an email when the mailman puts something in but i want the number in the mail as well,but i cant get it to work.
i want something like this: you have (number) pieces of mail
this is the script:
x = uservariables["postteller"] + 1
if (otherdevices['brievenbus'] == 'On') then
commandArray['Variable:postteller'] = tostring(x)
print (x)
commandArray['SendEmail']='post#er is post bezorgd#[email protected]'
if (otherdevices['brievenbus leeg'] == 'On') then
commandArray['Variable:postteller'] = tostring(0)
print ('brievenbus is geleegd, teller naar 0')
commandArray['SendEmail']='post#de brievenbus is geleegd, teller is gereset#[email protected]'
dannybloe
Re: lua user variable number in email
Post by dannybloe »
Using dzVents it would be like this (no user variables needed):
	active = true,
		'brievenbus',
		'brievenbus leeg'
	data = {
		postTeller = { initial = 0 }
		if (device.name == 'brievenbus' and device.state == 'On') then
			-- brievenbus was triggered
			domoticz.data.postTeller = domoticz.data.postTeller + 1
			domoticz.email('Post', 'Er is post bezorgd. Teller: ' .. tostring(domoticz.data.postTeller), '[email protected]')
		elseif (device.state == 'On') then
			-- brievenbus leeg was triggered
			domoticz.data.postTeller = 0
			domoticz.email('Post', 'De brievenbus is geleegd. Teller is gereset', '[email protected]')
tiga
Post by tiga »
thanks for your effort but cant i just use my lua script??
a have a second problem.i want to send an email to 2 emailadresses.i do it like this:
print (x)
what am i doing wrong becouse only the 2nd email adres is getting the email.i tryed to switch the adresses or use an other one but only the 2nd in line gets the email.
jvdz
Domoticz version: 4.107
Post by jvdz »
Try:
commandArray[1]={['SendEmail']='post#er is post bezorgd#[email protected]' }
commandArray[2]={['SendEmail']='post#er is post bezorgd#[email protected]' }
Jos
dannybloe
Post by dannybloe »
tiga wrote:thanks for your effort but cant i just use my lua script??
print (x)
Of course you can use your own Lua script. Just showing you that things can be done a lot easier. Easier to learn, easier to read.
Anyway, you can concatenate strings in Lua like this:
 commandArray['SendEmail']='post#er is post bezorgd.Teller:' .. tostring(x) .. '#[email protected]'
tiga
Post by tiga »
ok thank you verry much for all your effort!
i will take a look at dcvents maybe that is better for a new person like me ;-)
