Arduino mega and ESP8266
Posted: Thursday 16 June 2016 23:00
I am working to send collected data from the arduino mega to domoticz with the ESP 8266 wifi chip connected to the TX16 and RX 17 port of the mega module.
At this moment i am able to perform a get request but when i build a post request i get a 400 bad request or a 404 error.
What have I done until now:
- Flash ESP8266 with firmware: v0.9.2.2 AT Firmware.bin
- Tested the post request with chrome browser => Result is OK and value is updated.
Is there anny one with experiance to perform a POST from arduino with the ESP8266?
Below my code until now:
#define SSID "****"
#define PASS "****"
#define DEST_HOST "json.htm?type=command¶m=udevice&idx=20&nvalue=0&svalue=5"
#define DEST_IP "192.168.0.15"
#define TIMEOUT 5000 // mS
#define CONTINUE false
#define HALT true
// #define ECHO_COMMANDS // Un-comment to echo AT+ commands to serial monitor
// Print error message and loop stop.
void errorHalt(String msg)
Serial.println(msg);
Serial.println("HALT");
while(true){};
// Read characters from WiFi module and echo to serial until keyword occurs or timeout.
boolean echoFind(String keyword)
byte current_char = 0;
byte keyword_length = keyword.length();
// Fail if the target string has not been sent by deadline.
long deadline = millis() + TIMEOUT;
while(millis() < deadline)
if (Serial2.available())
char ch = Serial2.read();
Serial.write(ch);
if (ch == keyword[current_char])
if (++current_char == keyword_length)
Serial.println();
return true;
return false; // Timed out
// Read and echo all available module output.
// (Used when we're indifferent to "OK" vs. "no change" responses or to get around firmware bugs.)
void echoFlush()
{while(Serial2.available()) Serial.write(Serial2.read());}
// Echo module output until 3 newlines encountered.
// (Used when we're indifferent to "OK" vs. "no change" responses.)
void echoSkip()
echoFind("\n"); // Search for nl at end of command echo
echoFind("\n"); // Search for 2nd nl at end of response.
echoFind("\n"); // Search for 3rd nl at end of blank line.
// Send a command to the module and wait for acknowledgement string
// (or flush module output if no ack specified).
// Echoes all data received to the serial monitor.
boolean echoCommand(String cmd, String ack, boolean halt_on_fail)
Serial2.println(cmd);
#ifdef ECHO_COMMANDS
Serial.print("--"); Serial.println(cmd);
#endif
// If no ack response specified, skip all available module output.
if (ack == "")
echoSkip();
// Otherwise wait for ack.
if (!echoFind(ack)) // timed out waiting for ack string
if (halt_on_fail)
errorHalt(cmd+" failed");// Critical failure halt.
return false; // Let the caller handle it.
return true; // ack blank or ack found
// Connect to the specified wireless network.
boolean connectWiFi()
String cmd = "AT+CWJAP=\""; cmd += SSID; cmd += "\",\""; cmd += PASS; cmd += "\"";
if (echoCommand(cmd, "OK", CONTINUE)) // Join Access Point
Serial.println("Connected to WiFi.");
return true;
Serial.println("Connection to WiFi failed.");
return false;
// ******** SETUP ********
void setup()
Serial.begin(9600); // Communication with PC monitor via USB
Serial2.begin(9600); // Communication with ESP8266 via 5V/3.3V level shifter
Serial2.setTimeout(TIMEOUT);
Serial.println("ESP8266 Demo");
delay(2000);
//echoCommand("AT+RST", "ready", HALT); // Reset & test if the module is ready
Serial.println("Module is ready.");
echoCommand("AT+GMR", "OK", CONTINUE); // Retrieves the firmware ID (version number) of the module.
echoCommand("AT+CWMODE?","OK", CONTINUE);// Get module access mode.
// echoCommand("AT+CWLAP", "OK", CONTINUE); // List available access points - DOESN't WORK FOR ME
echoCommand("AT+CWMODE=1", "", HALT); // Station mode
echoCommand("AT+CIPMUX=1", "", HALT); // Allow multiple connections (we'll only use the first).
//connect to the wifi
boolean connection_established = false;
for(int i=0;i<5;i++)
if(connectWiFi())
connection_established = true;
break;
if (!connection_established) errorHalt("Connection failed");
delay(5000);
//echoCommand("AT+CWSAP=?", "OK", CONTINUE); // Test connection
echoCommand("AT+CIFSR", "", HALT); // Echo IP address. (Firmware bug - should return "OK".)
//echoCommand("AT+CIPMUX=0", "", HALT); // Set single connection mode
// ******** LOOP ********
void loop()
// Establish TCP connection
String cmd = "AT+CIPSTART=0,\"TCP\",\""; cmd += DEST_IP; cmd += "\",8084";
if (!echoCommand(cmd, "OK", CONTINUE)) return;
delay(2000);
// Get connection status
if (!echoCommand("AT+CIPSTATUS", "OK", CONTINUE)) return;
// Build HTTP request.
cmd = "POST / HTTP/1.1\r\nHost: "; cmd += DEST_HOST; cmd += ":8084\r\n\r\n";
// Ready the module to receive raw data
if (!echoCommand("AT+CIPSEND=0,"+String(cmd.length()), ">", CONTINUE))
echoCommand("AT+CIPCLOSE", "", CONTINUE);
Serial.println("Connection timeout.");
return;
// Send the raw HTTP request
echoCommand(cmd, "OK", CONTINUE); // GET
// Loop forever echoing data received from destination server.
while(true)
while (Serial2.available())
errorHalt("ONCE ONLY");
