Door Lock - IDLock whit z-wave modul
SuperZite
Post by SuperZite »
Just got my new door lock, its from IDLock.no whit a z-wave modul,
This lock is not in the manufacture_spcific.xml file so i added the manufacture
<Manufacturer id="0230" name="IDLock">
      <Product type="0003" id="0001" name="Door lock whit RFID and z-wave"/>
</Manufacturer>
It show´s up like switch but are only getting:
Received timeout notification from HomeID.
in the log when trying the switch.
Do i have to make a manufacture xml whit the use of the guide to the lock whit the Command Class
http://idlock.no/media/wysiwyg/Bruksanv ... l%20EN.pdf
SuperZite
Re: Door Lock - IDLock whit z-wave modul
Post by SuperZite »
Removed
SuperZite
Post by SuperZite »
Solution was to enable NetworkKey but that i did have to do in the options.xml file. under domoticz/Config.
But i still need there is needed for a config xml file.
and it shows inverted status :-(
SuperZite
Post by SuperZite »
Beginning of a xml file..
        <CommandClasses>
            <CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="98">
                <Instance index="1" />
            </CommandClass>
            <CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
            </CommandClass>
            <CommandClass id="94" name="COMMAND_CLASS_ZWAVE_PLUS_INFO" version="1" request_flags="4" innif="true">
                <Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
                <Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="768" />
                <Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="768" />
            </CommandClass>
            <CommandClass id="98" name="COMMAND_CLASS_DOOR_LOCK" version="1" request_flags="4" issecured="true" m_timeoutsupported="2" m_insidehandlemode="15" m_outsidehandlemode="15" m_timeoutmins="254" m_timeoutsecs="254">
                <Value type="bool" genre="user" instance="1" index="0" label="Locked" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
                <Value type="list" genre="user" instance="1" index="1" label="Locked (Advanced)" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                    <Item label="Unsecure" value="0" />
                    <Item label="Unsecured with Timeout" value="1" />
                    <Item label="Inside Handle Unsecured" value="2" />
                    <Item label="Inside Handle Unsecured with Timeout" value="3" />
                    <Item label="Outside Handle Unsecured" value="4" />
                    <Item label="Outside Handle Unsecured with Timeout" value="5" />
                    <Item label="Secured" value="255" />
                    <Item label="Invalid" value="255" />
                </Value>
                <Value type="list" genre="system" instance="1" index="2" label="Timeout Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
                    <Item label="No Timeout" value="1" />
                    <Item label="Secure Lock after Timeout" value="2" />
                </Value>
                <Value type="int" genre="system" instance="1" index="3" label="Timeout Minutes" units="Mins" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="254" />
                <Value type="int" genre="system" instance="1" index="4" label="Timeout Seconds" units="Secs" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="254" />
                <Value type="byte" genre="system" instance="1" index="5" label="Outside Handle Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="15" />
                <Value type="byte" genre="system" instance="1" index="6" label="Inside Handle Control" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="15" />
            </CommandClass>
            <CommandClass id="99" name="COMMAND_CLASS_USER_CODE" version="1" request_flags="4" issecured="true" codes="52">
                <Value type="raw" genre="user" instance="1" index="0" label="Enrollment Code" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="1" label="Code 1:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="2" label="Code 2:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="3" label="Code 3:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="4" label="Code 4:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="5" label="Code 5:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="6" label="Code 6:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="7" label="Code 7:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="8" label="Code 8:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="9" label="Code 9:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="10" label="Code 10:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="11" label="Code 11:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="12" label="Code 12:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="13" label="Code 13:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="14" label="Code 14:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="15" label="Code 15:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="16" label="Code 16:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="17" label="Code 17:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="18" label="Code 18:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="19" label="Code 19:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="20" label="Code 20:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="21" label="Code 21:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="22" label="Code 22:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="23" label="Code 23:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="24" label="Code 24:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="25" label="Code 25:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="26" label="Code 26:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="27" label="Code 27:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="28" label="Code 28:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="29" label="Code 29:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="30" label="Code 30:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="31" label="Code 31:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="32" label="Code 32:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="33" label="Code 33:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="34" label="Code 34:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="35" label="Code 35:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="36" label="Code 36:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="37" label="Code 37:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="38" label="Code 38:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="39" label="Code 39:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="40" label="Code 40:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="41" label="Code 41:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="42" label="Code 42:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="43" label="Code 43:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="44" label="Code 44:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="45" label="Code 45:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="46" label="Code 46:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="47" label="Code 47:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="48" label="Code 48:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="49" label="Code 49:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="50" label="Code 50:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="51" label="Code 51:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="raw" genre="user" instance="1" index="52" label="Code 52:" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00" length="10" />
                <Value type="button" genre="system" instance="1" index="254" label="Refresh All UserCodes" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="byte" genre="system" instance="1" index="255" label="Code Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="52" />
            </CommandClass>
            <CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
            </CommandClass>
            <CommandClass id="113" name="COMMAND_CLASS_ALARM" version="4" issecured="true">
                <Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="byte" genre="user" instance="1" index="9" label="Access Control" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
                <Value type="byte" genre="user" instance="1" index="10" label="Burglar" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
                <Value type="byte" genre="user" instance="1" index="13" label="Emergency" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
            </CommandClass>
            <CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
            </CommandClass>
            <CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
                <Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                    <Item label="Normal" value="0" />
                    <Item label="-1dB" value="1" />
                    <Item label="-2dB" value="2" />
                    <Item label="-3dB" value="3" />
                    <Item label="-4dB" value="4" />
                    <Item label="-5dB" value="5" />
                    <Item label="-6dB" value="6" />
                    <Item label="-7dB" value="7" />
                    <Item label="-8dB" value="8" />
                    <Item label="-9dB" value="9" />
                </Value>
                <Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
                <Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                </Value>
                <Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
                <Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
                    <Item label="Failed" value="0" />
                    <Item label="Success" value="1" />
                    <Item label="In Progress" value="2" />
                </Value>
                <Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="10" />
            </CommandClass>
            <CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
                <Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
            </CommandClass>
            <CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" issecured="true">
                <Associations num_groups="1">
                    <Group index="1" max_associations="5" label="Group 1" auto="true">
                        <Node id="1" />
                    </Group>
                </Associations>
            </CommandClass>
            <CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" issecured="true">
                <Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
                <Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.05" />
                <Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.00" />
            </CommandClass>
            <CommandClass id="152" name="COMMAND_CLASS_SECURITY" version="1" request_flags="4" innif="true">
                <Value type="bool" genre="system" instance="1" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
            </CommandClass>
        </CommandClasses>
SuperZite
Post by SuperZite »
XMl file.. but can only get the Door Lock mode to work. its made whit use of the PDF in first post.
<?xml version="1.0" encoding="utf-8"?>
<Product xmlns='http://code.google.com/p/open-zwave/'>
<!-- Configuration Parameters -->
<!--COMMAND_CLASS_CONFIGURATION-->
<CommandClass id="112">
    <Value type="list" index="1" genre="config" label="Door Lock Mode" units="" min="0" max="3" size="1">
      <Help>
        	Door Lock Mode
		Autolock Mode, Manuallock mode, Activate Away Mode, Deactivate Away Mode.
		Default Value : 1 ( Disable Away / Auto Lock Mode )
      </Help>
      	<Item label="Disable Away Manual Lock" value="0" />
      	<Item label="Disable Away Auto Lock" value="1" />
	<Item label="Enable Away Manual Lock" value="2" />
	<Item label="Enable Away Auto Lock" value="3" />
    </Value>
	<Value type="list" index="2" genre="config" label="RFID Registration Configuration" units="" min="0" max="3" size="1">
      <Help>
        	IDLocks can use up to 50 RFID cards. In order to use a RFID, RFID has to be registered by z-wave configuration command class.
		Configuration Set in case of starting to register from backend side ( Ex. App)
      </Help>
      		<Item label="Begin RFID Registering mode on the door lock" value="0x01" />
      		<Item label="RFID Database clear" value="0x07" />
		<Item label="RFID Registering mode stop" value="0x08" />
	</Value>
</CommandClass>
	<!-- Association Groups -->
<!--COMMAND_CLASS_ASSOCIATION-->
            <CommandClass id="133">
                    <Group index="1" max_associations="1" label="IDLock" auto="true">
                     </Group>
                </Associations>
            </CommandClass>
</Product>
Is it possible to make scenc og rules based on the info found in openzwave controlpanle. Door is sending information if someone uses the wrong kode..
Olgmo
Domoticz version: 4.10717
Post by Olgmo »
So your latest XML works with the lock?
I tried but did not get any status changes.
Olgmo
Post by Olgmo »
Are you able to get correct door status from the lock?
And are you able to lock/unlock the door from Domoticz?
SuperZite
Post by SuperZite »
Olgmo wrote:Are you able to get correct door status from the lock?
No it´s inverted :-(
Olgmo wrote:And are you able to lock/unlock the door from Domoticz?
Yes, that is working. In OpenZwave Control panel i can also set timeout and see what device opening the door..
Olgmo
Post by Olgmo »
Strange.. My device say "Closed" whatever I do. (close/open from Domoticz or close/open from door)
Even got a replacement RFID chip to test, but no change.
SuperZite
Post by SuperZite »
Olgmo wrote:Strange.. My device say "Closed" whatever I do. (close/open from Domoticz or close/open from door)
Have you upgraded domoticz after you connected the lock ?
if so .. check the security key..
Olgmo
Post by Olgmo »
I did not use secure inclusion, do you think it's required?
SuperZite
Post by SuperZite »
If you dont use the secure you cant control the lock.
Olgmo
Post by Olgmo »
Your´re right. Works with secure to lock :-)
ulf_slask
Post by ulf_slask »
This one may help!
idlock z-wave IDL Operational Manual EN_.pdf
(363.43 KiB) Downloaded 247 times
