rfxcom ignore a switch update done by lua
Posted: Saturday 11 June 2016 11:07
Hi all !
It's my first post on this forum so let me first thanks all the team for this great piece of software domoticz is
I'm running into a funny problem, your support will be welcome : I'm running dev version 3.5231 ; I have a On/Off switch which drives a ZK1PA relay via rfxcom. It works well when I click on the switch from the web interface, my relay switches on and off as desired.
Ex :
and the relay is toggling in real life
Then, I wrote a lua script to toggle this switch on some criterias :
This commandArray toggle the switch correctly in domoticz : I can see it in the web interface, in the sensor logs, it's taken into account by other lua scripts. However, the rfxcom is not sending the command to the relay in that case :
What am I doing wrong ?
Thanks for your help !
Ex :
2016-06-11 10:44:16.561 User: Admin initiated a switch command
2016-06-11 10:44:16.562 (RfxCom) Lighting 1 (Filtration piscine)
if (MinDuJour >= PpeStart and MinDuJour < PpeStop and Filtration == "Off") then
-- Filtration On
print("Filtration piscine : Démarrage par timer")
commandArray[CmdIdx] = {['UpdateDevice'] = idxPpe..'|1|On'}
CmdIdx=CmdIdx+1
if (MinDuJour >= PpeStop and Filtration == "On") then
-- Filtration Off
print("Filtration piscine : Arrêt par timer")
commandArray[CmdIdx] = {['UpdateDevice'] = idxPpe..'|0|Off'}
CmdIdx=CmdIdx+1
2016-06-11 10:45:01.145 LUA: Script Filtration Piscine
2016-06-11 10:45:01.145 LUA: Filtration piscine : Démarrage par timer
2016-06-11 10:45:01.147 EventSystem: Script event triggered: /opt/domoticz/scripts/lua/script_time_piscine.lua
*nothing here :(*
2016-06-11 10:45:08.587 Hardware Monitor: Fetching data (System sensors)
2016-06-11 10:45:13.321 EventSystem: Script event triggered: /opt/domoticz/scripts/lua/script_device_elec.lua
