Page 1 of 2
Lua and Kodi
Posted: Tuesday 07 June 2016 23:51
by rickwilleme
Guys,
I'm new to Lua and I'm feeling like a total noob here..
Once my doorbell is pressed, I would like to run a Lua script so my camera feed is being showed on my screen.
Secondly, as long as it's playing anything else but music (like a movie), it has to pause it.
I got this far:
if (devicechanged['DummyDeurbel']=='Group On') then
print("Dummy Deurbel!")
if (otherdevices['HTPC - Kodi'] ~= "Audio") then
commandArray['HTPC - Kodi']='Pause'
commandArray['HTPC - Kodi']='Execute script.securitycam'
The individual Pause and Execute statements work, but not while they're in the same script.
I think the array item for the HTPC - Kodi device gets overridden. Can anyone confirm?
So how can this be done from the same script?
Any help is appreciated!
Thanks,
Rick
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 8:05
by simonrg
commandArray is purely an array, so you are setting the 'HTPC - Kodi' item to 'Pause', then this value is overwritten by 'Execute ....'.
Domoticz allows you to use a different mechanism by allowing nested arrays - have a look at the wiki page
http://www.domoticz.com/wiki/Events
Rewritting you script as below should work:
i = 0
i = i + 1
commandArray[i]={ ['HTPC - Kodi'] = 'Pause' }
i = i + 1
commandArray[i] = { ['HTPC - Kodi'] = 'Execute script.securitycam' }
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 8:06
by MatthijsPH
Can't you make script.securitycam pause Kodi?
Sent from my HTC One_E8 dual sim using Tapatalk
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 9:00
by dannybloe
I'd use dzVents for this. If there are Kodi specific commands missing then I can add them.
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 9:30
by rickwilleme
simonrg wrote:commandArray is purely an array, so you are setting the 'HTPC - Kodi' item to 'Pause', then this value is overwritten by 'Execute ....'.
i = 0
i = i + 1
i = i + 1
Thanks simonrg for your help. Unfortunately, it doesn't seem to work as well.
Even if I simplify my code to the one below, only the last command gets executed.
commandArray[1] = { ['HTPC - Kodi'] = 'Execute script.securitycam' }
commandArray[2] = { ['HTPC - Kodi'] = 'Pause' }
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 9:32
by rickwilleme
MatthijsPH wrote:Can't you make script.securitycam pause Kodi?
Hi Matthijs,
Fair point. However, I did not write that script myself and don't want to mess around with it too much.
Rather keep all the logic and events in one place (Domoticz)
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 9:41
by rickwilleme
dannybloe wrote:I'd use dzVents for this. If there are Kodi specific commands missing then I can add them.
Thanks Danny, looks very promising! Has this already been implemented in the latest Domoticz build or do I still need to install it manually? (Currently using 3.5228)
Re: Lua and Kodi
Posted: Wednesday 08 June 2016 9:47
by dannybloe
You still need to install it manually (just copy some files, quite easy. Instructions are in the manual).
Re: Lua and Kodi
Posted: Thursday 09 June 2016 0:07
by rickwilleme
dannybloe wrote:You still need to install it manually (just copy some files, quite easy. Instructions are in the manual).
I performed the steps described on Github, but it doesn't look like the event gets triggered. (Nothing is listed in the logs after triggering the test script with a switch)
Re: Lua and Kodi
Posted: Thursday 09 June 2016 8:33
by dannybloe
rickwilleme wrote:dannybloe wrote:You still need to install it manually (just copy some files, quite easy. Instructions are in the manual).
- Make sure you have the dzVents folder in the correct place with all its contents (../domoticz/scripts/lua/dzVents)
- puy both scripts script_device.main.lua and script_time_main.lua in your Lua script folder (../domoticz/scripts/lua) and
- you renamed the settings file to dzVents_settings.lua (and set the http parameters inside to correct ip address etc).
- You created a subfolder 'scripts' inside your Lua folder (../domoticz/scripts/lua/scripts) and
- in there create a script file according to the examples/generic.lua (edited to your needs).
- Make sure the script is active: active=true
If you put this script in the scripts folder you should see stuff in the logs:
active = true,
'<exact name of the switch of id of the switch>'
execute = function(domoticz, switch)
domoticz.log('This should show up in the logs when the switch is triggerd')
domoticz.log(tostring(switch.state))
If the switch isn't triggered, make sure the name or the id is correct in your 'on' part of the script. Always check the domoticz log. dzVents does a lot of reporting there.
Re: Lua and Kodi
Posted: Thursday 09 June 2016 8:55
by rickwilleme
Figured out that my folder structure was incorrect. (Even after checcking.....)
Is this why they say that you shouldn't combine coding with alcohol?
Re: Lua and Kodi
Posted: Thursday 09 June 2016 8:59
by dannybloe
Let me know if there still problems or missing kodi support.
Re: Lua and Kodi
Posted: Thursday 09 June 2016 10:13
by rickwilleme
What command should I use for executing the Kodi script?
Tried two ways but neither of them seem to work. Pausing video does work, so I know the Lua script is being triggered well.
active = true,
'DummyDeurbel'
execute = function(domoticz, mySwitch)
if (mySwitch.state == 'Group On') then
local kodi = domoticz.devices['HTPC - Kodi']
-- Pause if not playing music
if (kodi.state ~= "Audio") then
kodi.state = 'Pause'
-- Execute script SecurityCam
kodi.state = 'Execute script.securitycam'
kodi.execute = 'script.securitycam'
Re: Lua and Kodi
Posted: Thursday 09 June 2016 10:31
by dannybloe
active = true,
'DummyDeurbel'
No, I guess this won't work indeed. So, let's start at the beginning. I assume that you do get into the first if-block right? Second, modifying devices with dzVents is not by setting the state. You have to use any of the device methods as listed
here. So in your case you could try kodi.setState('Pause').
Third, I just learned there are specific kodi commands (from the wiki):
commandArray['Lounge']='Off'
commandArray['Lounge']='Pause'
commandArray['Lounge']='Set Volume 30'
commandArray['Lounge']='Play Playlist Indierock'
commandArray['Lounge']='Play Playlist ActionMovies 15'
commandArray['Lounge']='Play Favorites'
commandArray['Lounge']='Play Favorites 3'
commandArray['Lounge']='Execute script.securitycam'
Currently there is no kodi support in dzVents specific for this so you have to use the generic methods:
domoticz.sendCommand('HTPC - Kodi', 'Execute script.securitycam')
so your script will be something like this:
active = true,
'DummyDeurbel'
execute = function(domoticz, deurbel)
if (deurbel.state == 'Group On') then
I will add the kodi commands and let you know.
Re: Lua and Kodi
Posted: Thursday 09 June 2016 10:56
by rickwilleme
Seems like it's the old scenario all over again.
Individual commands work great, but as soon as a second command should be executed, only the last one gets send to Kodi
active = true,
'DummyDeurbel'
domoticz.sendCommand('HTPC - Kodi', 'Paused')
This only triggers the securitycam script..
Re: Lua and Kodi
Posted: Thursday 09 June 2016 11:18
by dannybloe
Ah, I get it. I assume that the command is not properly handled by the plugin then. I tried to see if I can see anything in the Domoticz code but couldn't see it. I guess you should create a ticket in github for it.
In the meantime.. can you do this from the Domoticz GUI? If so then there is probably a json command that you send instead (inspect the Network tab in your browser console).
Re: Lua and Kodi
Posted: Thursday 09 June 2016 17:32
by dannybloe
I assume you did use 'Pause' instead of 'Paused' right?
Re: Lua and Kodi
Posted: Thursday 09 June 2016 20:23
by dannybloe
I just created the
Kodi commands in dzVents. (
dev branch). Maybe you could give it a try to see if it works.
- kodiExecuteAddOn(addonId): Function. Will send an Execute Addon command sending no parameters. Addon IDs are embedded in the addon configuration and are not to be confused with the Addon Name. For example: http://forums.homeseer.com/showthread.php?p=1213403.
- kodiPause(): Function. Will send a Pause command, only effective if the device is streaming.
- kodiPlay(): Function. Will send a Play command, only effective if the device was streaming and has been paused.
- kodiPlayFavorites([position]): Function. Will play an item from the Kodi's Favorites list optionally starting at position. Favorite positions start from 0 which is the default.
- kodiPlayPlaylist(name, [position]): Function. Will play a music or video Smart Playlist with name optionally starting at position. Playlist positions start from 0 which is the default.
- kodiSetVolume(level): Function. Set the volume for a Kodi device, 0 <= level <= 100.
- kodiStop(): Function. Will send a Stop command, only effective if the device is streaming.
- kodiSwitchOff(): Function. Will turn the device off if this is supported in settings on the device.
Cheers,
Danny
Re: Lua and Kodi
Posted: Thursday 09 June 2016 22:44
by rickwilleme
Thanks Danny for the quick support on this
Unfortunately I still have the same issue.
This only pauses:
active = true,
'DummyDeurbel'
kodi.kodiExecuteAddOn('script.securitycam')
kodi.kodiPause()
This only shows the security cam overlay:
active = true,
'DummyDeurbel'
kodi.kodiPause()
For the record; this is the log:
2016-06-09 22:40:44.422 LUA: Handling events for: "DummyDeurbel", value: "Group On"
2016-06-09 22:40:44.423 LUA: =====================================================
2016-06-09 22:40:44.423 LUA: >>> Handler: kodi
2016-06-09 22:40:44.423 LUA: >>> Device: "DummyDeurbel" Index: 330
2016-06-09 22:40:44.423 LUA: .....................................................
2016-06-09 22:40:44.424 LUA: .....................................................
2016-06-09 22:40:44.424 LUA: <<< Done
2016-06-09 22:40:44.424 LUA: -----------------------------------------------------
2016-06-09 22:40:44.425 LUA: [1] = HTPC - Kodi: Execute script.securitycam
2016-06-09 22:40:44.425 LUA: [2] = HTPC - Kodi: Pause
2016-06-09 22:40:44.425 LUA: =====================================================
2016-06-09 22:40:44.434 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_main.lua
Re: Lua and Kodi
Posted: Thursday 09 June 2016 22:47
by dannybloe
I'd make a ticket in github tracker for Domoticz.
