Honeywell TH8320ZW1000 thermostat
dthompson
Post by dthompson »
I just installed a Honeywell TH8320ZW1000 (Zwave) thermostat to my Domoticz 3.4834 Raspberry PI system. It joined easily and I have access to the heating setpoints, cooling setpoints, fan mode (Auto, On, Recirc), and system mode (Auto, heat, cool, off). But, when I look at the OpenZwave Control Panel there are also an Operating State (heating/cooling/idle) and Fan State (idle/on) which show the actual state of each. These values reflect if the thermostat has the fan commanded on or off, as well as if it's heating or cooling.
My question is how do I get these added as devices so that I can see them on my Dashboard or other tabs? As well as, use those values in Blockly or other scripts?
Thanks for your help!!
