How to adjust the temperature
Posted: Tuesday 07 June 2016 11:10
by fantom
I using domoticz from one year, but I don't know how to do such a thing:
1) using slider (or up/down, or edit or ...) set temperature (float value) by user
2) switch valve by compare this value and reading temperature from other sensor. This is easier.
Is it posible ?
how easily user can set the value ?
Fantom
Re: How to adjust the temperature
Posted: Tuesday 07 June 2016 11:27
by fantom
I found dummy virtual device "thermosts setpoint".
Is it the solution ?
Fantom
Posted: Thursday 09 June 2016 8:23
by gizmocuz
yes
Posted: Saturday 11 June 2016 7:36
by kathleencjustice
Try that may be it will work for you.
Posted: Saturday 01 October 2016 16:22
by foad62
Where can I find dummy virtual device "Thermostat Setpoint"?!
I've added "Dummy (Does nothing, use for virtual switches only)" but when I go to switches section I cannot find any sort of thermostat setpoint!
I'm using Domoticz V3.4834
Posted: Saturday 01 October 2016 16:29
by fantom
I have
Text
Thermostat setpoint
Usage
Fantom
Posted: Sunday 02 October 2016 8:32
by foad62
thanks fantom
I found it in setup->hardware->create virtual device
Is there a way to define margin for on/off action for example with 0.5 degree margin. If virtual thermostat is set on 23 degree the relay turn on at 23.5 degree and turn off at 22.5 degree?
