Qubino 0-10v ZMNHVD1 working!
Posted: Monday 06 June 2016 21:56
by Machielw
Just connected the ZMNHVD1 to the airfan in my house. It is working with domoticz and the buva boxstream.
it is not well recognised, but working well without any configurations.
now Waiting for official openzwave support.
Re: Qubino 0-10v ZMNHVD1 working!
Posted: Monday 06 June 2016 23:07
by mbliek
How did you connect it? Can you still use the original wired remote?
Posted: Wednesday 08 June 2016 23:20
by Ron
Interested as wel.
I am looking for a wireless solution for 0-10V heating and cooling systems.
If this module has a real 0-10V output than it would probably be very interesting.
Posted: Wednesday 15 June 2016 19:41
by Machielw
For connecting, I used he info from this topic:
viewtopic.php?t=7294
Does anybody know if this config file will work?
http://www.cd-jackson.com/index.php/zwa ... =openzwave
Posted: Sunday 17 July 2016 9:46
by finalcut62
I have the same Qubino 0-10V flush dimmer, but it is not recognized in Domoticz, because it isn't on the supported list of OpenZWave at the moment. How did you get it working with Domoticz?
Posted: Wednesday 27 July 2016 19:57
by HeTi
I can see ZMNHVDx in current openzwave tree:
https://github.com/OpenZWave/open-zwave ... fig/qubino
Any idea when openzwave will update current domoticz version ?
Or howto update myself ?
Posted: Monday 01 August 2016 22:05
by finalcut62
I just updated OpenZwave and rebuilt Domoticz, but the Qubino wasn't recognized. So, still interested in making this device work!
EDIT: Use "include secure" to add the device instead of "include". That's the trick - it works now.
EDIT2: "Include secure" gives errors. But now regular include works too. Just for instruction purposes, my steps:
Step 1: As per instructions in INSTALL.TXT (domoticz), Update OpenZWave:
cd open-zwave
git pull
make clean
make
cd ..
Step 2: Rename current domoticz directory
mv domoticz domoticz.BAK
Step 3: As per instructions in INSTALL.TXT, download and build domoticz again:
git clone https://github.com/domoticz/domoticz.git domoticz
cd domoticz
git pull
cmake -DCMAKE_BUILD_TYPE=Release .
make
I then noticed that ~/domoticz/Config/qubino doesn't include the ZMNHVDx.xml file still. So then I did the following:
Step 4: Copy appropriate XML files from openzwave directory:
cd ~/domoticz/Config/qubino
cp ~/open-zwave-read-only/config/qubino/ZMNHVDx.xml .
cd ..
cp ~/open-zwave-read-only/config/manufacturer_specific.xml .
rm zwcfg_0x*.xml
reboot and add the Qubino device regularly
Now, it may very well be that you could skip Step 3 altogether as the new build didn't install the right XML files anyway, but I'm just listing my steps...
Posted: Wednesday 10 August 2016 15:36
by leby
I can add that the module also works for controlling led driver with 1-10V dimming function. Perfect dimming with no flicker!
Posted: Friday 25 November 2016 23:16
by sumo89
Hi!
I also have this one now and dimming works just fine! :)
I have a PT-100 thermometer sensor connected to the input, and set parameter 1 to 'thermometer'. Now I have 3 devices, one 'level' for the output and 2 'switch'... Don't know what those are used for?
How am I supposed to get the reading from the temp input? :) I can see that I have voltage in to the Qubino that changes with the temperature.
Posted: Saturday 26 November 2016 12:35
by HeTi
I've never used inputs, but I think that it must also be a "0-10V".
You need PT100 -> 0-10V converter.
I tried once to get Lux meter to work, but I did not get any sensible readings.
Posted: Saturday 26 November 2016 20:04
by sumo89
I have one of these: https://www.aliexpress.com/item/NEW-PT1 ... 4.1.y4kpxm
Mine is 0-300C, so I guess 10/300 = 0.033V per C. I tried in my living room and I get around 0.78V which is about 23C! :) And if I heat it up a bit I get like 1.2V, so it seems to be working.
But I followed the Qubino manual and I switch Parameter 1 to Temp, then I'm supposed to exclude it (without resetting to default) and add again after 30s. Now I expect it to be included and create two devices - 0-10V output "level"-type and a thermometer-type... So I guess this is either a OpenZwave or Domoticz issue?
Posted: Sunday 27 November 2016 12:31
by Domosapiens
This works for the Dimmer Qubino ZMNHDD1 temp DS18b20 connection
Dimmer Qubino ZMNHDD1 temp DS18b20 connection.jpg (23.76 KiB) Viewed 5028 times
I assume the ZMNHVD1 has the same capability
DS18b20 bought here:
https://nl.aliexpress.com/item/2-x-DS18 ... 87306.html
And here:
https://nl.aliexpress.com/item/Free-Shi ... goryId=523
Dimmer Qubino ZMNHDD1 temp DS18b20 connection2.jpg (21.68 KiB) Viewed 5028 times
And this JST 1.5mm plug
https://nl.aliexpress.com/item/10-Sets- ... =200001565
Check the collors&connections, they can be different
Posted: Monday 28 November 2016 6:03
by sumo89
Thanks Domosapiens!
Though, I'm going to put it down chimney, so it needs to handle at least 200C! I haven't found any DS18b20 that can do that. That was why I went with the PT100 and a 0-10V converter. :)
Posted: Monday 28 November 2016 11:07
by Domosapiens
Ok.
Is your solution 1-Wire compatible?
http://neutrino.phys.ksu.edu/~gahs/doub ... S18B20.pdf
Because that's what the Qubino expects on the TS input.
Sorry, now I see: You use the I1 input !
The Excluding/Including procedure is for the TS input only(I think).
Posted: Monday 19 December 2016 8:58
by sumo89
I got this answer from Qubino directly:
"To read data from input I1, there must be configured multichannel association lifeline, but there is a problem, domoticz does not support multichannel association."
