RFXtrx433 not receiving
RobDob
Domoticz version: v2.2563
Post by RobDob »
Is anyone seeing issues with their RFXtrx's? Yesterday morning at about 1am both of mine stopped receiving information from my sensors.
I have a RFXtrx433 and a RFXtrx433E. Both of these are connected to a Windows computer that runs Domoticz. The devices are in separate rooms with one directly connected to the computer and the other connected by a Belkin Network USB Hub (other devices connected to this are working).
I have stopped Domoticz and ran RFXmngr and it can see both devices and what their settings are but I see no devices sending information. I have tried the RFXtrx433 in another computer with RFXmngr and get the same results.
I have flashed them both with the latest Type1 Firmware and have the same results.
I have emailed their support and will see what they say but wondered if anyone else is seeing something like this - its very odd that they both stopped at the same time and wont work in another system - its almost like a certificate has expired or something similar.....
Thanks,
Rob
b_weijenberg
Re: RFXtrx433 not receiving
Post by b_weijenberg »
If both stopped at the same moment it is not expected to be an error in both RFXtrx at the same time.
Also if it operates before it is not expected to be a firmware problem.
It is most probably an RF noise source that transmits constantly so that a receiver cannot receive any valid packet anymore.
Another reason could be a lightning strike very close to the receivers.
To be sure, test the RFXtrx on another location far from the current location using RFXmngr on a Windows system or laptop.
Test with a remote or sensor (not the bad sensor) to see if the RFXtrx receives this device.
In most cases we have seen this problem created by an X10 MS13 motion sensor with an almost empty battery. Or a weather sensor with almost empty battery or the sensor filled with water.
RFX-433, RFX-433EMC, RFX-868
RobDob
Post by RobDob »
So some sensors started to report back but not many. I have about 20 sensors in all. There is no X10 in the house, I removed that a while back. No lightning here lately. I have changed the batteries in the Wind and Rain sensors.
I have slowly been turning things off 1 by 1 to try and find what's doing it, things got better when I removed a Siemens 433MHz plug socket but they are still not as they were before.
I will keep trying to see what is interfering as it appears to be more than one thing.
b_weijenberg
Did you test the RFXtrx433 already at another location far away from the current location? (> 1km)
RobDob
Post by RobDob »
No, not had a chance to yet. Other than my wind sensor things seem to be back to normal.
Westcott
Post by Westcott »
UPDATE
After reconnecting to my PC and restarting RFXmgr, it's now receiving OK!
I am having the same problem of not receiving anything.
It's now connected to RFXmngr, but nothing is being logged.
The "Set mode" and "Get status" buttons do not get any data after the initial connection.
Reset receiver/transceiver
Get Status
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 1
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1005
Firmware Type = Ext
Transmit power = 10dBm
Hardware version = 1.3
Undec off
X10 disabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech disabled
Oregon Scientific disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
Rubicson disabled
FineOffset disabled
Lighting4 enabled
RSL disabled
Byron SX enabled
Imagintronix disabled
KeeLoq disabled
Home Confort disabled
RFU2 disabled
RFU3 disabled
RFU4 disabled
RFU5 disabled
RFU6 disabled
RFU7 disabled
Set Mode
Set Mode
Set Mode
Get Status
Get Status
b_weijenberg
This seems not to be a Domoticz problem!
Please contact support rfxcom.com
Westcott
Post by Westcott »
Perhaps I should have mentioned that RFXmngr eventually started to receive, but Domoticz does not, even after several restarts.
Nor does the protocol status get listed when the RFXCOM hardware is started in Domoticz.
I seee "RFXCOM: Using serial port: /dev/ttyUSBx" but no further RFX messages.
fountside
Post by fountside »
This is strange because mine stopped receiving a couple of days ago too. I suspected there was a problem with the actual hardware as the 'rec' light does not illuminate when I press my LightwaveRF mood controllers now.
It does however receive temp and humidity information from the Oregon Scientific sensors I have, and also can transmit all signals perfectly. Is this a coincidence with us both?
I tried updating the firmware and this has not helped.
b_weijenberg
Did the problem occur after a firmware or Domoticz update?
Please connect the RFXtrx433 to a Windows system and check with RFXmngr if you receive LWRF remotes. Test first with only the LigtwaveRF protocol enabled.
Westcott
Post by Westcott »
I had already updated to 1005.
It does transmit OK, but receives nothing.
EdwinE
Post by EdwinE »
I have tried to install the rfxcom433 with no luck.
Adding hardware goes fine. devices shows up on the right ttyUSB1.
When I want to change mode, add tickboxes it never saves it. nomatter what I am doing anything when I return all ticks are gone.
when adding a switch, adding goes fine. but no response whatsoever of the switch itself.
using the windows tool is going well.
Anyone any idea what is going on here? I have rebooted twice. took the rfx out, in, out...
b_weijenberg
EdwinE: which Domoticz version do you run?
fountside
Post by fountside »
My problem was fixed yesterday, I updated the firmware on the RFXtrx433 and then replaced batteries in all my X10 sensors. This has solved my issue.
Luigi87
Post by Luigi87 »
I had some issues with my Domoticz and the RFXcom last weeks. My RFXcom would not send any commands anymore.
with my settup is had something to do with Virtualbox.
But after a reinstall on a PI 3B it is working again.
Check also on your RFXcom it is not in bootloader mode. the red LED is on constandly.
This prevents the RFXcom from setting the diffrent modes.
