Mi-Light State
Terence
Mi-Light State
Post by Terence »
I have just connected my miloght bridge and it seems to work great turning on and off.
I was going someone could help, domoticz does not seem to hold the correct state of the lights, for eg it will show that the lights are off when the are actually on or vice versa
Can anybody help?
bizziebis
Domoticz version: 3.8805
Re: Mi-Light State
Post by bizziebis »
Do you mean when you switch them on/off with Domoticz? That should work without a problem. But when you turn on/off the lights with a mii light remote Domoticz will not know because it's one directional communication.
Stuntteam
Re: Mi-Light State
Post by Stuntteam »
Note that when you use RFLink to act as a bridge then also state changes caused by remotes are recorded.
Unlike the milight bridge which can only transmit, RFLink can also receive milight signals.
pluggin
Re: Mi-Light State
Post by pluggin »
Some times I have the same issue when used the physical switch instead the virtual switch.
All my light switches are Aeotec Micro Smart Energy Switch G2
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
