Page 1 of 2
SolarEdge api
Posted: Sunday 05 June 2016 14:07
by petroman
I am new to the domotica world so bare with me.
We have a solaredge system on the roof and I wnat to use domoticz with the api.
I installed the latest stable version of domotic,
Ad hardware via api key,
I also allowed devices for 5min,
but I can't get devices.
Can anybodu point me in the right direction ?
O, yes sun is shining and solar system is on line.
Best regards,
Wim
Via the logfile I see this:
2016-06-05 12:07:14.683 Domoticz V3.4834 (c)2012-2016 GizMoCuz
2016-06-05 12:07:14.683 Build Hash: 8398125, Date: 2016-03-02 08:43:51
2016-06-05 12:07:18.184 Active notification subsystems: http (1/11)
2016-06-05 12:07:18.184 WebServer(HTTP) started on address: :: with port 8080
2016-06-05 12:07:18.278 WebServer(SSL) started on address: :: with port 443
2016-06-05 12:07:18.278 Proxymanager started.
2016-06-05 12:07:18.278 Starting shared server on: :::6144
2016-06-05 12:07:18.278 TCPServer: shared server started...
2016-06-05 12:07:18.278 RxQueue: queue worker started...
2016-06-05 12:07:18.488 Incoming connection from: 127.0.0.1
2016-06-05 12:07:20.309 EventSystem: reset all events...
2016-06-05 12:07:20.309 EventSystem: reset all device statuses...
2016-06-05 12:07:20.310 EventSystem: Started
2016-06-05 12:30:47.534 SolarEdgeAPI Worker started...
2016-06-05 12:34:10.725 SolarEdgeAPI Worker stopped...
2016-06-05 12:50:55.905 SolarEdgeAPI Worker stopped...
2016-06-05 13:51:26.016 New sensors allowed for 5 minutes...
2016-06-05 13:51:57.138 New sensors allowed for 5 minutes...
2016-06-05 14:03:11.148 SolarEdgeAPI Worker started...
2016-06-05 14:03:25.185 SolarEdgeAPI Worker stopped...
2016-06-05 14:03:44.935 SolarEdgeAPI Worker started...
2016-06-05 14:03:57.415 New sensors allowed for 5 minutes...
Re: SolarEdge api
Posted: Sunday 05 June 2016 14:26
by CurrentThread
First make sure that your API key and Site ID are both correct. Check it with this URL replacing the SITEID and APIKEY with yours:
https://monitoringapi.solaredge.com/sit ... key=APIKEY
If correct the browser result is XML output with the generated Wh between 01-06-2016 and 05-06-2016.
Re: SolarEdge api
Posted: Sunday 05 June 2016 14:51
by petroman
Thanks for the fast answer: the site id is the numer or the name you gave your installation ?
I use both but they both give a 403 error: Access to the specified resource () has been forbidden.
But maybe I change the wrong code part:
https://monitoringapi.solaredge.com/sit ... 360U4U53DZ..
I removed the last two letters from the apikey.
eDIT:
SORRY,
THERE WAS AN UISSUE WITH GENERATION THE KEY. i GENERATED THE API KEY BUT SOMEWHERE ON THE BOTTUM OF THE PAGE STOOD: SAVE.
sorry 2: capslock was on.
So now I saved the api key, I get this back:
DAYWhINVERTER2016-06-01 00:00:006356.8742016-06-02 00:00:005551.5022016-06-03 00:00:004698.00342016-06-04 00:00:008817.3022016-06-05 00:00:009512.474
But still no devices.
Re: SolarEdge api
Posted: Sunday 05 June 2016 15:12
by CurrentThread
Correct serial number in the hardware settings?
Re: SolarEdge api
Posted: Sunday 05 June 2016 15:30
by petroman
CurrentThread wrote:Correct serial number in the hardware settings?
Yes, checked that again.
The log now says:
2016-06-05 15:24:35.155 Active notification subsystems: (0/11)
2016-06-05 15:24:37.365 Active notification subsystems: (0/11)
2016-06-05 15:26:15.318 New sensors allowed for 5 minutes...
2016-06-05 15:27:03.642 Error: SolarEdgeAPI: Error getting http data!
It suggest it has contact but doesn't get the data.
- Image1.jpg (109.6 KiB) Viewed 10287 times
Re: SolarEdge api
Posted: Sunday 05 June 2016 16:01
by CurrentThread
The Domoticz process can access the internet (no firewall blocking)?
You get that error if the following HTTP request does not return a valid result. Can you try this URL in a web browser, replacing YOUR_SITEID, YOUR_SERIAL and YOUR_APIKEY with the values in your Domoticz hardware settings?
https://monitoringapi.solaredge.com/equ ... OUR_APIKEY
Re: SolarEdge api
Posted: Sunday 05 June 2016 17:08
by petroman
CurrentThread wrote:The Domoticz process can access the internet (no firewall blocking)?
Works,
Get a load of data.
Edit:
So, I do not know why but suddenly there was some communication.
The only difference is that I rebooted the PC and mnitor network behaviour via my eset smart security. To be sure that this din't block traffic.
Now is the question (sorry),
1) what determines the items I can monitor,
2) what is the refresh rate ?
3) how can I edit the refresh rate ?
4) where can I alther the values settings ? Last row, frequency is in percentage, which is not correct.
And off coarse THANK YOU for all the help.
Log:
2016-06-05 16:53:55.050 Error: SolarEdgeAPI: Error getting http data!
2016-06-05 16:58:23.622 New sensors allowed for 5 minutes...
2016-06-05 16:58:56.541 (Solarman) General/kWh (kWh Meter)
2016-06-05 16:58:56.622 (Solarman) General/Voltage (DC)
2016-06-05 16:58:56.693 (Solarman) Temp (SolarMain)
2016-06-05 16:58:56.770 (Solarman) General/Voltage (AC)
2016-06-05 16:58:56.832 (Solarman) General/Percentage (Hz)
Re: SolarEdge api
Posted: Sunday 05 June 2016 17:23
by CurrentThread
Is that "Error: SolarEdgeAPI: Error getting http data!" line repeating in the log each x seconds?
And Domoticz can access the internet? To verify you can try the Weather Underground integration with Domoticz for example. It needs internet to get the actual weather.
Re: SolarEdge api
Posted: Sunday 05 June 2016 17:40
by petroman
CurrentThread wrote:Is that "Error: SolarEdgeAPI: Error getting http data!" line repeating in the log each x seconds?
Weather Underground integration ?
Is this the forecast under the tab weather ? If so it works.
But I don't see errors anymore in the log too, so it looks something fixed itself.
Although that is scary.
I edited my message so our messages crossed in time.
Re: SolarEdge api
Posted: Sunday 05 June 2016 18:21
by CurrentThread
If it is running fine, SolarEdge via Web API hardware is requesting new data every five minutes. And only from one hour before sunrise until one hour after sunset. So make sure your location is set in the Domoticz settings.
Re: SolarEdge api
Posted: Sunday 05 June 2016 18:34
by petroman
CurrentThread wrote:If it is running fine, SolarEdge via Web API hardware is requesting new data every five minutes. And only from one hour before sunrise until one hour after sunset. So make sure your location is set in the Domoticz settings.
ok, thanks.
I am already excited. I used the search but is tehre a specific topi about solar edge ?
Because their own monitoring tool shows more information then the five parameters I now have/get.
For instance: power/temp/current per panel ?
Re: SolarEdge api
Posted: Sunday 05 June 2016 20:12
by CurrentThread
The info per panel is only visible via the SolarEdge Portal website or app. I don't think that information is exposed via the SolarEdge API. All API options are described here:
http://www.solaredge.com/files/pdfs/se_ ... ng_api.pdf
Re: SolarEdge api
Posted: Monday 13 June 2016 10:08
by multispeed
i have a similair problem..
I see data when i goto
i see data:
{"data":{"count":26,"telemetries":[{"date":"2016-06-01 18:00:00","totalActivePower":308.0,"dcVoltage":748.0,"groundFaultResistance":6900.04,"powerLimit":100.0,"totalEnergy":12827.0,"temperature":39.4267,"inverterMode":"MPPT","vL1To2":406.688,"vL2To3":403.969,"vL3To1":406.0,"L1Data":{"acCurrent":0.726562,"acVoltage":236.281,"acFrequency":50.0223,"apparentPower":171.0,"activePower":102.0,"reactivePower":-137.0,"cosPhi":1.0},"L2Data":{"acCurrent":0.734375,"acVoltage":233.609,"acFrequency":50.021,"apparentPower":172.0,"activePower":102.0,"reactivePower":-142.0,"cosPhi":1.0},"L3Data":{"acCurrent":0.734375,"acVoltage":232.328,"acFrequency":50.0236,"apparentPower":172.0,"activePower":104.0,"reactivePower":-136.0,"cosPhi":1.0}},{"date":"2016-06-01 18:05:00","totalActivePower":284.0,"dcVoltage":747.625,"groundFaultResistance":6900.04,"powerLimit":100.0,"totalEnergy":12853.0,"temperature":39.3658,"inverterMode":"MPPT","vL1To2":405.625,"vL2To3":402.312,"vL3To1":405.0,"L1Data":{"acCurrent":0.703125,"acVoltage":236.047,"acFrequency":49.9932,"apparentPower":165.0,"activePower":91.0,"reactivePower":-137.0,"cosPhi":1.0},"L2Data":{"acCurrent":0.71875,"acVoltage":232.328,"acFrequency":49.9929,"apparentPower":169.0,"activePower":91.0,"reactivePower":-140.0,"cosPhi":1.0},"L3Data":{"acCurrent":0.726562,"acVoltage":231.891,"acFrequency":49.9918,"apparentPower":167.0,"activePower":102.0,"reactivePower":-134.0,"cosPhi":1.0}},{"date":"2016-06-01
But i get no devices... Not even when i allow devices for 5 minutes...
The log tells me:
2016-06-13 09:26:53.740 Domoticz V3.5241 (c)2012-2016 GizMoCuz
2016-06-13 09:26:53.756 Build Hash: 141e2b2, Date: 2016-06-13 08:42:30
2016-06-13 09:26:54.100 Active notification subsystems: http (1/11)
2016-06-13 09:26:54.178 WebServer(HTTP) started on address: :: with port 8080
2016-06-13 09:26:54.959 WebServer(SSL) started on address: :: with port 443
2016-06-13 09:26:54.959 Proxymanager started.
2016-06-13 09:26:54.975 Starting shared server on: :::6144
2016-06-13 09:26:54.975 TCPServer: shared server started...
2016-06-13 09:26:54.975 RxQueue: queue worker started...
2016-06-13 09:26:56.553 Incoming connection from: 192.168.1.82
2016-06-13 09:26:57.022 EventSystem: reset all events...
2016-06-13 09:26:57.053 SolarEdgeAPI Worker started...
2016-06-13 09:26:57.053 EventSystem: reset all device statuses...
2016-06-13 09:26:57.084 EventSystem: Started
2016-06-13 09:33:35.958 Incoming connection from: ::1
2016-06-13 09:41:02.979 Incoming connection from: 192.168.1.71
2016-06-13 09:48:12.273 New sensors allowed for 5 minutes...
2016-06-13 09:48:34.856 SolarEdgeAPI Worker stopped...
2016-06-13 09:48:34.856 SolarEdgeAPI Worker started...
2016-06-13 10:02:08.591 Incoming connection from: 192.168.1.181
Can anyone point me in the right direction ?
Re: SolarEdge api
Posted: Friday 12 August 2016 16:51
by WardjeP
I'm also new in the world of Domoticz and Raspberry. But..... It's up and running so far
We also have a solar systeem with a SolarEdge SE5000 converter. I've entered the Site-ID, Serial number and Site API code but in the lof file is the same message as mentioned above (Petroman):
2016-08-12 16:14:00.943 SolarEdgeAPI Worker started...
2016-08-12 16:14:16.464 Error: SolarEdgeAPI: Error getting http data!
2016-08-12 16:19:27.013 Error: SolarEdgeAPI: Error getting http data!
2016-08-12 16:24:37.561 Error: SolarEdgeAPI: Error getting http data!
Every 5 minutes.....
I've used the link with adapted data and received data from the site, but not in Domoticz.....
The installation is new. (Yesterday). Is it a matter of time?
Re: SolarEdge api
Posted: Wednesday 07 September 2016 13:18
by mcwieger
Same issue as above:
2016-09-07 13:02:11.957 Error: SolarEdgeAPI: Invalid data received!
2016-09-07 13:07:15.488 Error: SolarEdgeAPI: Invalid data received!
2016-09-07 13:07:45.008 Error: SolarEdgeAPI: Invalid data received!
2016-09-07 13:08:08.461 Error: SolarEdgeAPI: Invalid data received!
2016-09-07 13:13:11.992 Error: SolarEdgeAPI: Invalid data received!
And on the API page of SolarEdge:
type Status report
message
description Access to the specified resource () has been forbidden.
And no devices are added. Any progress from anyone?
Re: SolarEdge api
Posted: Wednesday 14 September 2016 12:02
by mcwieger
Ok, RTFM:
https://www.domoticz.com/wiki/SolarEdge
I used the user api key instead of the site key. I received the right key from SolarEdge and now working as expected.
Re: SolarEdge api
Posted: Monday 17 October 2016 16:23
by rizzah
Hi All,
I have the same problem as this topic starter it seems. Also im new to this
I have all the right info (siteID/serial/etc) and i dont see any errors in the logs. However i dont know where i can find out if its receiving any data, because the only thing i see in the log is :
2016-10-17 15:31:53.073 SolarEdgeAPI Worker stopped...
2016-10-17 15:31:53.073 SolarEdgeAPI Worker started...
And thats it. The Pi3 tunning domoticz has internet connection. I tried the above suggestions with the URL, and i got a nice xml responce from that.
Any other reason why i wouldnt see the SolarEdge in my devices list? As a side question, how often does the devices list get updated?
Regards,
Peter
Re: SolarEdge api
Posted: Wednesday 07 December 2016 19:38
by litfiba
Hi Everyone!
It seems I got the same issue related to this topic. I'm able to receive a json response when requesting "
https://monitoringapi.solaredge.com/equ ... ey=API_KEY":
EG:
{"data":{"count":447,"telemetries":[{"date":"2016-12-01 18:49:56","totalActivePower":0.0,"dcVoltage":null,"powerLimit":0.0,"totalEnergy":40344.0,"temperature":0.0,"inverterMode":"SLEEPING","vL1To2":408.219,"vL2To3":410.969,"vL3To1":412.5,"L1Data":{"acCurrent":0.0,"acVoltage":235.375,"acFrequency":49.9897,"apparentPower":0.0,"activePower":0.0,"reactivePower":0.0,"cosPhi":0.0},"L2Data":
But In Domoticz with same parameters I only got "SolarEdgeAPI Worker started...", no errors... but NO DEVICES..
Please, does anyone solved this issue?
Re: SolarEdge api
Posted: Wednesday 07 December 2016 20:05
by litfiba
multispeed wrote:i have a similair problem..
i see data:
The log tells me:
Hi Guys, did someone find a solution to this? I get the similar issue...
Re: SolarEdge api
Posted: Thursday 08 December 2016 15:01
by rizzah
I had it working for a day or two, all of the sudden the devices were added and were receiving data, after couple days it stopped, eventho i didnt touch anything.
