P1 suddenly not showing data
Posted: Thursday 02 June 2016 19:53
Suddenly P1 is not showing any values. 433 mhz hardware and S0 hardware are working fine.
No errors in the Domoticz log.
P1 device is shown when using the command "ls -l /dev/tty*"
But no data is shown if I use the command "cat /dev/ttyP1". When using the command "cat /dev/ttyS0" correct values are shown.
Things I did:
We are using a Landis Gyr E350 DSMR 4.0.
Things I did:
- Disconnect en reconnect P1 cable
Reboot Raspberry
Use other USB port
New image on Raspberry
Bought new P1 cable
