Event not working - Some help please
Cognac
Domoticz version: Newest
Post by Cognac »
I have a Domoticz switch which turns on/off a relay (connected by using ESP Easy). This works fine.
I added a PIR sensor to this ESP8266, which also works fine.
Now I want to set the relay off, when there is no motion detected for x seconds using events. However this event doesn't work (other events work fine).
Could you please give me some support on the event below.
Thanks in advance! :)
pir koffie event.jpg (30.93 KiB) Viewed 1326 times
Egregius
Domoticz version: v2024.7
Re: Event not working - Some help please
Post by Egregius »
Are you sure the state is 'no motion' of the pir?
Use the 'current state' function in the events screen to double check.
Cognac
Post by Cognac »
Egregius wrote:Are you sure the state is 'no motion' of the pir?
Unfortunately yes. See screenshot.
Egregius
Post by Egregius »
You mean no?
It says 'off' and not 'no motion'.
So change your script to if PIR Koffie == Off and ...
Cognac
Post by Cognac »
I changed and is not working. Seems that it is not possible to on/off the relay (Rancillio aan/uit) by using events. :S
Even the below event does not work (event is set on active, also under settings).
jvdz
Domoticz version: 4.107
Post by jvdz »
Did "PIR Schuur" actually change the status from On to Off when you tested as this blockly only will be triggered when the device changes status?
Jos
