script lua night lamp
Posted: Friday 27 May 2016 19:31
by Mazzokun
Hi guys, I'm trying writing a lua script to put on some light if time is night but there are some mistake.. can someone help me? :D
commandArray{}
if time > Sunset or time < Sunrise and
otherdevices['Corridoio'] == 'Off'
or otherdevices['Lampada Sala'] == 'Off'
or otherdevices['Faro Retro'] == 'Off'
or otherdevices['Faro Garage'] == 'Off'
or otherdevices['Lanterna Ingresso'] == 'Off'
or otherdevices['Lanterna Nonna'] == 'Off'
or otherdevices['Accento Ingresso'] == 'Off'
or otherdevices['Lampione'] == 'Off'
or otherdevices['Luce Garage'] == 'Off'
then
commandArray['Corridoio'] == 'On'
commandArray['Lampada Sala'] == 'On'
commandArray['Faro Retro'] == 'On'
commandArray['Faro Garage'] == 'On'
commandArray['Lanterna Ingresso'] == 'On'
commandArray['Lanterna Nonna'] == 'On'
commandArray['Accento Ingresso'] == 'On'
commandArray['Lampione'] == 'On'
commandArray['Luce Garage'] == 'On'
elseif time= Sunrise commandArray[group:Luci Notturne] == 'Off'
Re: script lua night lamp
Posted: Friday 27 May 2016 19:47
by jvdz
Normally it helps when you state what kind of error you get or what isn't working. ;)
I've made some changes like adding brackets and a then on the elseif line but am not sure i found all issues:
commandArray{}
if (time > Sunset or time < Sunrise)
and (otherdevices['Corridoio'] == 'Off'
	or otherdevices['Luce Garage'] == 'Off')
		then
		commandArray['Corridoio'] = 'On'
		commandArray['Lampada Sala'] = 'On'
		commandArray['Faro Retro'] = 'On'
		commandArray['Faro Garage'] = 'On'
		commandArray['Lanterna Ingresso'] = 'On'
		commandArray['Lanterna Nonna'] = 'On'
		commandArray['Accento Ingresso'] = 'On'
		commandArray['Lampione'] = 'On'
		commandArray['Luce Garage'] = 'On'
elseif time == Sunrise then
		commandArray[group:Luci Notturne] = 'Off'
Jos
Posted: Friday 27 May 2016 22:50
by Mazzokun
Thanks ;) .
This is log error for your code.
Error: EventSystem: in script_device_powerknnlkkn: [string "commandArray = {}..."]:3: attempt to compare two nil values
Posted: Friday 27 May 2016 22:55
by Flopp
Try to put -- in front of these rows
maybe it can be something with group i dont know if group has to be with a Capital G.
I have almost no knowledge of LUA so I always put -- in front of each row until it works then start to solve the problem
Posted: Friday 27 May 2016 22:57
by Flopp
OK found it, it has to be Capital G
https://www.domoticz.com/wiki/LUA_commands
Posted: Saturday 28 May 2016 7:31
by Mazzokun
I rewrote and this works :) Thank you for support!! :D
-- LUCI NOTTURNE
if (timeofday['Nighttime']) and otherdevices['Corridoio'] == 'Off'          then commandArray[1]={['Corridoio'] = 'On' }         end
if (timeofday['Nighttime']) and otherdevices['Lampada Sala'] == 'Off'       then commandArray[2]={['Lampada Sala'] = 'On' }      end
if (timeofday['Nighttime']) and otherdevices['Faro Garage'] == 'Off'        then commandArray[3]={['Faro Garage'] = 'On'}        end
if (timeofday['Nighttime']) and otherdevices['Lanterna Ingresso'] == 'Off'  then commandArray[4]={['Lanterna Ingresso'] = 'On'}  end
if (timeofday['Nighttime']) and otherdevices['Lanterna Nonna'] == 'Off'     then commandArray[5]={['Lanterna Nonna'] = 'On' }    end
if (timeofday['Nighttime']) and otherdevices['Lampione'] == 'Off'           then commandArray[6]={['Lampione'] = 'On' }          end
if (timeofday['Nighttime']) and otherdevices['Luce Garage'] == 'Off'        then commandArray[7]={['Luce Garage'] = 'On'}        end
if (timeofday['Nighttime']) and otherdevices['Faro Retro'] == 'Off'         then commandArray[8]={['Faro Retro'] = 'On'}         end
-- ACCENTI
if (timeofday['Nighttime']) and otherdevices['Accento Ingresso'] == 'Off'   then commandArray[9]={['Accento Ingresso'] = 'On'}   end
-- SPEGNIMENTO
if (timeofday['Sunrise']) then commandArray[10]={['Group:Luci Notturne'] = 'Off'} end
Posted: Saturday 28 May 2016 7:37
by Flopp
Great
