In Revision 33 my ELRO devices where working perfectly (except switch D
It will by great if there is a solution possible for this problem.
Revision 33
~~10;version;
20;01;VER=1.1;REV=33;BUILD=07;
HOMECODE 11000
UNIT A
20;2B;AB400D;ID=44;SWITCH=1;CMD=ON;
20;2C;AB400D;ID=44;SWITCH=1;CMD=OFF;
UNIT B
20;2D;AB400D;ID=44;SWITCH=2;CMD=ON;
20;2E;AB400D;ID=44;SWITCH=2;CMD=OFF;
UNIT C
20;2F;AB400D;ID=44;SWITCH=3;CMD=ON;
20;30;AB400D;ID=44;SWITCH=3;CMD=OFF;
UNIT D
20;31;AB400D;ID=44;SWITCH=4;CMD=ON;
20;32;Kaku;ID=4d;SWITCH=16;CMD=OFF; //DEVICE = WRONG SWITCH 4 STAYS ONCode: Select all
UNIT A ON
20;9C;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,900,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,150,930,180,900,840,270,180,900,840,270,180,930,810,270,180,900,810,270,180,900,180,930,180,930,810,270,180,6990;
20;9D;AB400D;ID=44;SWITCH=1;CMD=ON;
20;9E;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,930,810,270,180,900,810,270,180,930,810,270,180,930,840,270,180,930,810,270,180,930,810,270,180,930,810,270,840,270,840,270,810,270,840,270,180,6990;
UNIT A OFF
20;B3;DEBUG;Pulses=50;Pulses(uSec)=270,900,180,930,180,900,180,930,180,900,840,270,180,900,840,270,180,900,840,270,180,900,180,900,180,900,840,270,180,900,840,270,180,900,840,270,180,900,840,270,180,900,810,270,180,900,180,930,180,6990;
20;B4;AB400D;ID=44;SWITCH=1;CMD=OFF;
20;B5;DEBUG;Pulses=50;Pulses(uSec)=270,900,180,900,180,900,180,900,180,900,840,270,180,930,810,270,180,930,840,270,180,900,840,270,180,900,840,270,180,930,810,270,180,900,840,270,180,900,840,270,810,270,840,270,840,270,840,270,180,6990;
UNIT B ON
20;BE;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,900,180,930,810,270,150,930,810,270,180,930,810,270,180,930,180,930,150,930,810,270,180,6990;
20;BF;AB400D;ID=44;SWITCH=2;CMD=ON;
20;C0;DEBUG;Pulses=50;Pulses(uSec)=270,930,150,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,840,270,180,930,810,270,180,930,840,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT B OFF
20;C3;DEBUG;Pulses=50;Pulses(uSec)=240,930,180,930,150,930,180,930,180,930,810,270,150,930,810,270,180,930,810,270,150,930,810,270,180,930,180,930,150,930,810,270,180,930,810,300,150,930,810,270,180,930,810,270,180,930,180,930,180,6990;
20;C4;AB400D;ID=44;SWITCH=2;CMD=OFF;
20;C5;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,150,930,180,930,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,810,270,810,270,810,300,810,270,180,6990;
UNIT C ON
20;C6;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,300,150,930,810,270,180,930,810,270,150,930,810,270,180,930,810,300,150,930,180,930,180,930,810,300,150,930,810,270,180,930,180,930,150,930,810,270,180,6990;
20;C7;AB400D;ID=44;SWITCH=3;CMD=ON;
20;C8;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,150,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,150,930,810,300,180,930,810,300,810,270,810,270,810,300,810,300,150,6990;
UNIT C OFF
20;DE;DEBUG;Pulses=50;Pulses(uSec)=270,930,150,930,180,930,180,930,150,930,810,300,150,930,810,270,180,930,810,270,150,930,810,270,150,930,810,270,180,930,180,930,180,930,810,270,180,930,810,270,150,930,810,270,180,930,180,930,150,6990;
20;DF;AB400D;ID=44;SWITCH=3;CMD=OFF;
20;E0;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,150,930,180,930,180,930,810,270,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT D ON
20;E3;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,900,180,930,810,270,180,900,840,270,180,930,810,270,180,900,810,270,180,900,840,270,180,900,840,270,180,900,180,930,180,930,810,270,180,900,180,900,180,900,810,270,180,6990;
20;E4;AB400D;ID=44;SWITCH=4;CMD=ON;
20;E5;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,900,180,930,180,900,180,900,840,270,180,900,810,270,180,930,810,270,180,930,810,270,180,900,840,270,180,930,810,270,180,900,840,270,180,900,840,270,810,270,840,270,810,270,810,270,180,6990;
UNIT D OFF
20;E6;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,180,930,810,270,180,930,150,930,180,930,810,270,180,930,810,270,180,930,180,930,180,6990;
20;E7;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;E8;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;Code: Select all
~~10;version;
20;01;VER=1.1;REV=41;BUILD=03;
UNIT A
20;0D;TriState;ID=00a8aa;SWITCH=0;CMD=ON;
20;0E;TriState;ID=00a8aa;SWITCH=2;CMD=OFF;
UNIT B
20;0F;TriState;ID=00aa2a;SWITCH=0;CMD=ON;
20;10;TriState;ID=00aa2a;SWITCH=2;CMD=OFF;
UNIT C
20;11;TriState;ID=00aa8a;SWITCH=0;CMD=ON;
20;12;TriState;ID=00aa8a;SWITCH=2;CMD=OFF;
UNIT D
20;13;TriState;ID=00aaa2;SWITCH=0;CMD=ON;
20;14;Kaku;ID=4d;SWITCH=16;CMD=OFF;Code: Select all
UNIT A ON
20;18;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,900,810,270,180,930,810,270,180,930,810,270,180,930,150,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,180,930,810,270,180,6990;
20;19;TriState;ID=00a8aa;SWITCH=0;CMD=ON;
20;1A;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,180,930,810,270,180,930,810,270,180,930,780,270,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT A OFF
20;1B;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,300,150,930,810,270,150,930,810,270,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,900,810,270,180,930,180,930,180,6990;
20;1C;TriState;ID=00a8aa;SWITCH=2;CMD=OFF;
20;1D;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,150,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,300,810,300,810,270,840,270,810,270,180,6990;
UNIT B ON
20;1E;DEBUG;Pulses=50;Pulses(uSec)=270,930,150,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,150,930,180,930,810,270,180,6990;
20;1F;TriState;ID=00aa2a;SWITCH=0;CMD=ON;
20;20;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT B OFF
20;21;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,900,180,6990;
20;22;TriState;ID=00aa2a;SWITCH=2;CMD=OFF;
20;23;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,150,930,810,270,180,900,840,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT C ON
20;3D;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,150,930,180,930,810,270,180,930,810,270,180,930,180,930,180,930,810,270,180,6990;
20;3E;TriState;ID=00aa8a;SWITCH=0;CMD=ON;
20;3F;DEBUG;Pulses=50;Pulses(uSec)=270,930,150,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,150,6990;
UNIT C OFF
20;40;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,180,6990;
20;41;TriState;ID=00aa8a;SWITCH=2;CMD=OFF;
20;42;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,900,180,930,180,900,180,930,810,270,180,930,810,270,180,900,810,270,180,930,810,270,150,930,810,270,180,930,180,930,180,930,810,270,180,930,810,270,810,270,810,270,810,270,840,270,180,6990;
UNIT D ON
20;47;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,150,930,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,180,930,180,930,840,270,180,930,180,900,180,930,840,270,180,6990;
20;48;TriState;ID=00aaa2;SWITCH=0;CMD=ON;
20;49;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,840,270,180,930,810,270,150,930,810,270,180,930,810,270,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,810,270,810,270,810,270,810,270,180,6990;
UNIT D OFF
20;4A;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,150,930,180,930,150,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,270,150,900,180,930,180,930,810,270,180,930,810,270,180,930,180,900,180,6990;
20;4B;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;4C;DEBUG;Pulses=50;Pulses(uSec)=270,930,180,930,180,930,180,930,180,930,810,270,180,900,810,270,180,930,810,270,180,930,810,270,180,930,810,270,180,930,810,300,180,930,810,270,180,930,810,270,810,270,810,270,840,270,810,270,180,6990;
