Problem with voltage display Topic is solved
hyla
Domoticz version: current
Post by hyla »
not quite sure if this is the right place for my question ...
I'm using Domoticz 3.5176 and MySensors 1.5.
In order to have a display of the voltages of my various sensors I am sending those values like this:
(heavily shortened:)
    MyMessage battMsg(CHILD_ID_BATT, V_VOLTAGE);
    void setup()
        gw.present(CHILD_ID_BATT, S_MULTIMETER);
    void loop()
        gw.send(battMsg.set(batteryV, 1));
Doing that, I can have a look at the voltages under "Utility" and clicking "log" I get charts for "days, month, year"
Now, since a few versions ago (can't tell exactly, sorry) there are no values displayed in the "month" & "year" charts.
Any idea anyone why this should be so?
Apart from regular Domoticz updates there were no changes lately, especially in the sensor firmware.
Thanks,
Christoph
EDIT:
Gets weirder. It's got to do with the otherwise really fancy "min/max/avg" buttons. When I select "min" and "max" ONLY there is a display
again. Adding "avg" the chart is empty:
gizmocuz
Re: Problem with voltage display
Post by gizmocuz »
Send you a PM for a debug request
gizmocuz
Post by gizmocuz »
Solved in #5177
SweetPants
Post by SweetPants »
gizmocuz wrote:Solved in #5177
Not quite, i think it's back (avg) in at least 3.5271 maybe earlier
gizmocuz
Post by gizmocuz »
Dont experience this issue here:
SweetPants
Yep, you are right, the fix was implemented earlier (may 28), but i updated the beta on a later date (june 24). Working fine now, sorry for the misunderstanding.
