I'm using a Z-Wave ZME_UZB1 Me USB Stick and a Fibaro wall switch.
Every now and then I lose connection to the ZWave devices and have to reset my RaspberryPi.
The USB stick is powered via a USB hub. Domoticz version is 3.5176.
Is there a solution to this? Like a cyclic reboot of the Z-Wave device? Or a check if it is reachable
and a reboot if it isn't? How would I do that on the Raspi?
Thanks,
Christoph
Z-Wave ZME_UZB1 "hangs"
- mbliek
Re: Z-Wave ZME_UZB1 "hangs"
Do you use a separate power supply for the USB hub?
Could be that your raspberry hasn't got enough power for the UZB1
Op zoek naar een Domoticz Start Set?
hyla
- Domoticz version: current
Yep, two separate power supplies ...
Christoph
Christoph
Flopp
- Target OS: -
Could it be something that it is not same ground? since you have a different power supply for ZME?hyla wrote:Yep, two separate power supplies ...
Christoph
Is it possible to upgrade firmware for ZME_UZB1?
- mbliek
Christoph
Try if is works better when you connect it directly to you pi.
Some USB sticks don't work well when they are connected by a hub of even an USB extension cable.
