Lua Scripting - Combining And/Or's
jimtrout87
Post by jimtrout87 »
I'm quite new to Domoticz and have just started using Lua. I'm not sure if possible but is there a simple way to combine and statements.
Below is my script for my alarm sequence but I seem to be saying and this and this and this.... is this the only way or could this be cleaned up. I have tried a few options to no avail so far. The below does work ok but im sure It could be compacted. As im just starting it would be good to get into the correct habits now!
-- script_Alarm.lua
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
if ((otherdevices['Kitchen Motion'] == 'On' or otherdevices['Hallway Motion']  == 'On') and otherdevices['Jims Home'] == 'Off' and otherdevices['Kaths Home'] == 'Off' and otherdevices['Alarm'] == 'Off' and timedifference(otherdevices_lastupdate['Jims Home']) > 600 and timedifference(otherdevices_lastupdate['Kaths Home']) > 600) then
	print("Nobody Home and Motion dector Active, Rasing Alarm!")
    commandArray['Alarm'] = 'On FOR 10'
georgesattali
Re: Lua Scripting - Combining And/Or's
Post by georgesattali »
As for myself, there is only one optimisation you may do :
In
you could write "Raising Alarm" :lol:
the rest seems perfect to me.
See you,
GD.
jimtrout87
haha thanks - that's one way of dropping some text.
Thanks for clearing that up.I don't know enough about Lua but assumed you would be able to combine For example:
if(otherdevices(['Kitchen Motion'] or ['Hallway Motion']) =='On')
To me that seems logical but maybe not...
robpow
Domoticz version: Beta :)
Post by robpow »
Try:
if(otherdevices['Kitchen Motion'] =='On' or otherdevices['Hallway Motion'] =='On')
markk
Post by markk »
jimtrout87 wrote:I'm quite new to Domoticz and have just started using Lua. I'm not sure if possible but is there a simple way to combine and statements.
-- script_Alarm.lua
   t1 = os.time()
   return difference
I use a seperate dummy switch called "someone home" operated by a blockly like this:
Blocky event: IF "me home" AND "wife home" = OFF, THEN turn "someone home" = Off, ELSE IF "me home" OR wife home" = ON, THEN turn "someone home" = On.
This would reduce your script a little bit by just using "someone home" and also reduce any others you use in the future based on last person to leave/first person home. Lights off, appliances off etc etc.
georgesattali
good idea :
you could write :
motionDetected = (otherdevices['Kitchen Motion'] == 'On' or otherdevices['Hallway Motion']  == 'On')
nobodyshome    = (otherdevices['Jims Home'] == 'Off' and otherdevices['Kaths Home'] == 'Off')
if ( motionDetected and  nobodyshome
then
the combination if(otherdevices(['Kitchen Motion'] or ['Hallway Motion']) =='On') would be - if accepted - VERY oddly interpreted by lua -- well, it is not.
jimtrout87
Thanks Both, i do now have a Somonehome dummy switch and is done via blocky. I use it across many scripts so its easiest to leave where it is.
