i have a Push On switch, when i press it it goes on for about one second, then off again.
is there any way to change the timings on this? what i really need it it to go on for ¼ second, then off
anyone have any thoughts?
Push On Switch Timings
SHadley1138
- StanHD
Re: Push On Switch Timings
Timings are set in the "Off Delay" in the switch's edit page. Not sure if 1/4 second is possible, but bear in mind the web interface update is @ every 5 seconds, so things may be working correctly but not represented immediately on the display.
Python:- Broadlink RM2, Sonos
SHadley1138
Yeah, it's not quite what I need. If I press the remote briefly, the blind closes. Domoticz can send a similar signal, but the on/off takes about a second, and it needs to be much less
