Mysensors fail after upgrade from 3530 to 4834
ladekribs
Post by ladekribs »
dear all,
I upgraded my Raspberrypi SD card image installation from 3530 to 4834
via the webinterface upgrade function, after that the (Wifi Esp8266))Mysensors gateway did not work any longer
if I select update in the hardware the seems to restart the Mysensors gateway and reconnect to it but thats all it does.
so I telnet to the Mysensors gateway I can see that the gateway communicates with the nodes, but nothing reaches domoticz.
so I took another raspberrypi and installed 4834 version to it, and got the same result.
next step was to reinstall 3530 on the second rapberrypi and it works like charm
so do I do things wrong?
Regards Stefan
gizmocuz
Re: Mysensors fail after upgrade from 3530 to 4834
Post by gizmocuz »
Send you a PM
D'rMorris
Post by D'rMorris »
I had similar issues with MyS. Could you please share any info on this topic on how to resolve?
ladekribs
Post by ladekribs »
Hello gizmocuz,
I downloaded 5169 and unpacked it to a new domoticz directory, but get the same error as in 4834.
will try to get portforward going.
but I cannot create/answer PM I am still too Young :-)
NetEye
Post by NetEye »
Hello gizmocuc,
I also upgraded my SD card to 4834, and also the communication between the ESP and Domoticz does not work no more.
The ESP (flashed with ESPEasy) works, the data is alive.
Can you please send me the way to solve this?
Jan
